1970 cowl tag help needed
Old Apr 29, 2009 | 06:46 AM
rjspen's Avatar
I bought a 1970 442 that is painted sebring yellow.The guy I bought it from said he did not know what the original color was.I can not find any info on the paint codes. The trim tag reads
st 70 34467 e 272 bdy
tr 979 926 99568 A pnt
10b a31
Any help would be greatly appreciated.
Old Apr 29, 2009 | 07:41 AM
agtw31's Avatar
is that exactly how the numbers look on the plate??
looks like a porcelain white car originally.
sebring yellow would be a double dash special order code
Old Apr 29, 2009 | 08:10 AM
rjspen's Avatar
Thanks for the response. That is exactly how the tag reads. The only trace of old paint I have found is in the top well , and it is yellow.
Old Apr 29, 2009 | 08:16 AM
68Tom's Avatar
Remove a door sill plate. I'd bet it's still the original color under that. And if not, just lift the carpet a bit. You'll see the remains of the original color unless it was a full body-off restoration. Then I guess you might be out of luck.
Old Apr 29, 2009 | 10:06 AM
rjspen's Avatar
I removed door sill and kick panel all the evidence is yellow. Is there any way to look up those paint #s? Are they unusual?
Thanks, Rich
Old Apr 29, 2009 | 06:01 PM
wmachine's Avatar
Trying to remember member
No offense, but can you post a pic of the tag?
Old Apr 29, 2009 | 06:26 PM
rjspen's Avatar
I would be happy to if you would tell me how.
Thanks, Rich
Old Apr 29, 2009 | 06:52 PM
rjspen's Avatar
Let's see if this works.
Old Apr 29, 2009 | 07:28 PM
Cameo White's Avatar
Smile
70-34467 is a 1970 442 Convertible
E is the Linden NJ plant. 272 is the basic production sequence--a low number indicating an early build date
TR 979 should be saddle colored buckets
926 I've never seen a second 3 digit trim code here ,and this one isn't in my book. Others with more experience may have more information.
99568. I've never seen a 5 digit paint code before. Assuming the last 2 digits are the paint color, that would be 68, not a listed color in 1970. The top color A is white.
10B is your build date--2nd week in october (early, like the basic production sequence number)
A31 is power windows.
Hope this helped some. I have to say I've never seen a cowl tag quite as elongated as the one in your picture, but that may just be my inexperience.
Old Apr 29, 2009 | 07:44 PM
rjspen's Avatar
Thanks for the help. The tag is regular dimensions, it is just the angle that I had to take the picture at, with the hood on, distorted it.
Old May 2, 2009 | 07:38 AM
wmachine's Avatar
That is one very strange tag. I can only guess the oddity has to do with it being Linden built.
I'm not finding much different that you, Cameo.
E is the VIN code for Linden, but the Body Tag code for Linden Should be "BL".
All of the "926 99568 A" is a mystery. I'm not so sure the 926 is a second trim code, either.
Need to dig deeper!
Old May 4, 2009 | 10:31 AM
Actually, 68 was Cinnamon Bronze Poly in 1970, which was a Toro-only color. Curiouser and curiouser...
Old May 4, 2009 | 11:32 PM
mugzilla's Avatar
is Fast Enough ...
Shouldn't those body tag holes be filled ...
That is a '70 tag
Old May 6, 2009 | 06:14 AM
S.Fulton's Avatar
My trim code is 945 which is Garnet but mine was built in Canada and sold in US.
Look here: http://www.yearone.com/updatedsingle..._body_tags.htm
Old Apr 20, 2013 | 11:29 AM
GAOldsman's Avatar
"Car"mudgeon
Sorry I am late to this party but I just found this thread.
926-99568 is a Special Order Chevy Color (Non Olds Extra Charge) Paint by the name of Canary Yellow
duckblaster67
Nov 24, 2020 03:01 PM
jimz70
Dec 8, 2013 03:24 PM
socalrs
May 24, 2012 06:38 PM
DesertToro
Jan 16, 2007 07:10 PM
Mr. King
Jan 14, 2007 07:47 PM
