1969 non tilt cutlass AT steering column
Old Mar 7, 2015 | 03:44 AM
Oldwolf's Avatar
I have a question about the parts in the upper column. When I removed the steering Wheel it looks like i'm missing some parts, and i'm unsure of how the short spring should fit. Spring before the horn contakt ring or after?
Old Mar 7, 2015 | 03:48 AM
Oldwolf's Avatar
Old Mar 8, 2015 | 08:47 PM
70Post's Avatar
The short stiff spring goes UNDER the grey (or greenish..can't tell exact color)plastic piece in your pic (which I assume you're referring to as the "contact ring"). That plastic piece is called the "cancelling cam" not the horn contact ring (which is something completely different).
So.....spring, cancelling cam, lock plate, small wire retainer ring (you may need a tool to depress the lock plate, etc to install it easier), etc
EDIT: the plastic piece I'm referring to (cancelling cam) is shown in your SECOND picture.
Old Mar 11, 2015 | 02:53 AM
Oldwolf's Avatar
Thank you, that clears it up a bit. I dont have the lock plate and the proper small wire retainer. Do you know how I can bye them? What does the lock plate lock? Is it nessesary to have that? can I take a washer instead of the lockplate?
Stanley
Old Mar 11, 2015 | 07:05 AM
oldspackrat's Avatar
Stanley,
I have all those parts, I'll get pix if you want. Shipping would probably be higher than the cost of the parts though.
Scott
Old Mar 11, 2015 | 11:40 AM
Oldwolf's Avatar
Smile
Originally Posted by oldspackrat
Stanley,
Scott
Probably, but maybe you have more parts I need. I send you a PM.
Old Mar 11, 2015 | 12:13 PM
mrolds69's Avatar
The lock plate is needed for the steering wheel to lock when the car is put in park and the key removed. A pin comes out of the column + locks in the plate. It's a good thing to have on there.
Old Mar 11, 2015 | 12:31 PM
Oldwolf's Avatar
OK, I get it. The steering column is shortened and it's going in a ****** Jeep so maybee its not that important but sure it is a safety device thats good. I have the pin that suppose to interlock with the lock plate. Thank you.
Stanley
starfire
Dec 9, 2021 08:21 PM
pfergy600
Jul 22, 2014 05:27 PM
317Cutty
Jun 18, 2014 10:53 AM
70Post
Jan 29, 2014 10:49 AM
ELECMAN
Jan 22, 2012 01:49 PM
