1968 Radiator Core Support Question
Old Sep 17, 2018 | 03:41 PM
Tjohn8573's Avatar
Hoping someone can tell me th answer to this question. Is there really a completely different radiator core supports for the 1968 Culass / 442 or is it just a different top plate that is used?
Old Sep 17, 2018 | 03:43 PM
Tjohn8573's Avatar
More detail for my question. I’m askung is there totally different core support for a HD radiator vs. a standard radiator? Or is just the top plate different?
Old Sep 17, 2018 | 04:46 PM
allyolds68's Avatar
The only difference with the core support between Heavy Duty and Standard cooling is the width of the radiator saddles at the bottom
Old Sep 17, 2018 | 08:59 PM
To clarify a little, two row and three row radiators use the same core support and top plate. Four row radiators use a different core support and top plate, but as Mike points out, the only difference in the core support is the wider lower saddles. These are spot-welded in place and can be swapped. Repros are available.
Old Sep 18, 2018 | 03:15 AM
Tjohn8573's Avatar
Thanks for the replies! That is what I was hoping to hear. They list two different part numbers in the assembly manual which was confusing.
Pacecar
Body work
Aug 27, 2012 06:44 PM
rroobble
Jan 19, 2011 05:49 PM
#1CutlassSupreme
Jun 11, 2008 02:03 PM
Resto Guy
Apr 28, 2008 07:48 PM
esisson
Jan 14, 2007 04:38 PM
