1968 Radiator Core Support Question
Hoping someone can tell me th answer to this question. Is there really a completely different radiator core supports for the 1968 Culass / 442 or is it just a different top plate that is used?
To clarify a little, two row and three row radiators use the same core support and top plate. Four row radiators use a different core support and top plate, but as Mike points out, the only difference in the core support is the wider lower saddles. These are spot-welded in place and can be swapped. Repros are available.
