1967 El Camino frame under 1964 Cutlass
Old Sep 3, 2019 | 07:24 PM
VinMichael's Avatar
I have a 1967 El Camino with no title. From what I hear the El Camino has a sturdier frame than what came in my 1964 Cutlass.
The El Camino has manual steering which I like. I could also build the frame while keeping my Cutlass drivable.
Would this be be a worthwhile swap? Any difference in the frames I should know of? I would part out the rest of the El Camino.
Old Sep 4, 2019 | 01:20 AM
Run to Rund's Avatar
Check the wheelbase--may be 119" vs. 115" for the Cutlass. Your Cutlass has a top and bottom tank radiator and the 67 is probably cross flow. The stronger frame results from it using the convertible type boxing.
Old Sep 4, 2019 | 01:38 AM
If you want manual steering, that simply swaps. The boxed convertible frame was an option on the 64-67 hardtops under RPO F35, but as Joe points out, the ElCo wheelbase is different.
Old Sep 4, 2019 | 09:45 AM
66-3X2 442's Avatar
The F-85/El Camino in 64 are both 115". My 64 442 Conv. had the El Camino frame with GM part # under it. There is/was a thread about this and Keener was the OP.
https://classicoldsmobile.com/forums...r-help-101686/
67Ragtop
Dec 6, 2018 01:30 PM
HonestDave
Apr 15, 2014 08:13 AM
Sethum
Oct 19, 2011 09:26 AM
66cutlass
Sep 21, 2010 11:16 AM
ROCKET JO
Dec 20, 2007 03:32 PM
