1967 Cutlass Fuel tank leak around sending unit
Old February 2nd, 2016, 02:31 PM
Rlasley's Avatar
The best I can tell, my 1967 Cutlass is leaking fuel around the sending unit when the tank is fuel. I am assuming I need to replace the sending unit. Do I have to drop the tank to replace the sending unit?
Rlasley is offline
Old February 2nd, 2016, 02:58 PM
Usually they leak at the rear rubber vent lines, or the rubber lines going to the sending unit. If it is in fact the sending unit then dropping the tank would be in order.
oldcutlass is online now
Old February 2nd, 2016, 03:04 PM
danktx's Avatar
I just replaced the sending unit on my 67 CS convertible. I did not have to drop the tank to replace the sending unit. It was easy to replace with the tank in place.
danktx is offline
Old February 2nd, 2016, 03:21 PM
Rlasley's Avatar
Ok. Thanks guys. I will take a closer look and see it's the lines or the unit. Then I will decide what I need to get and make the repair.
Rlasley is offline
Old February 2nd, 2016, 03:23 PM
But its so much easier to clean and treat the area where there is probably some corrosion with the tank out.
Old February 2nd, 2016, 04:24 PM
The Rocket Astronomer
lunaboy's Avatar
if you decide on a new sending unit i have one for the 67
lunaboy is offline
68RocketAction
December 18th, 2014 11:19 AM
pfergy600
October 4th, 2014 05:29 PM
1carsick
October 17th, 2012 09:10 AM
1k442
August 4th, 2011 11:28 AM
1k442
November 9th, 2010 08:31 AM
Quick Reply: 1967 Cutlass Fuel tank leak around sending unit
