1966 Window felt supplier
Old Sep 17, 2007 | 03:01 PM
jackedolds's Avatar
Does anyone know where to get window felts and rubbers (for inner and outer of windows) for a 66 cutlass coupe. This car has the chrome molding that goes over the top of the door and the felt attaches to it via bend over pins. The inner rubber attaches to the door panl via rivets.
All felts that I have found have a chrome bead on them and they do not attach to the factory chrome piece.
Any input on this problem would be appreciated.
THANKS.
Old Sep 17, 2007 | 03:33 PM
Check out Fusicks. I know they have window rubber and felt for my applications. I am sure if you look on their on-line catalog you will find what you are looking for.
http://www.fusick.com/
Old Sep 17, 2007 | 04:17 PM
THANKS.
I assume you're talking about the optional wide stainless trim on the door tops. I'm not aware of anyone making repros of these window felts. I have the same problem with my 70 W-30. It may be possible to buy the normal felts and carefully replace the old felts on your existing stainless trim. That's my plan, anyway, when I get to that point. You may want to buff out the stainless before installing the new felts. The inner should be the same as on all Cutlii of that year.
Old Sep 17, 2007 | 11:08 PM
88 coupe's Avatar
Junior Member
........ window felts and rubbers (for inner and outer of windows) for a 66 cutlass coupe ........
http://www.supercar.com
Norm
Old Sep 18, 2007 | 09:51 PM
Originally Posted by 88 coupe
Unfortunately, this site appears to sell only the normal window felt strips, not those for the option code B85 wide stainless belt molding. The B85 cars had (about 1") wide stainless bright molding along the window sills. The outer felt strips are attached to the stainless trim. This is different from the normal felts that have the small diameter round stainless bead. As I noted above, I am not aware of any repro source for these.
Old Sep 19, 2007 | 02:55 PM
88 coupe's Avatar
Junior Member
I am in contact with Ron at Supercar Specialty.
For clarification, Is this coupe a 2 door hardtop?
Norm
Old Oct 9, 2007 | 03:12 PM
jackedolds's Avatar
Smile reply to hardtop question:
yes it is a hardtop (2 door - no post car).
Old Jan 17, 2009 | 03:29 PM
Victory55's Avatar
Thanks for link, found the weather stripping I was looking for.
Old Jan 18, 2009 | 09:01 AM
88 coupe's Avatar
Junior Member
Good to hear.
And welcome to the site.
Norm
Old Jan 18, 2009 | 10:46 AM
442garage's Avatar
THANKS.
Steele Rubber has what you are looking for, as does Parts Place and Tamraz, both are in Chicago. The chrome moulding was the B85 option.
Old Jan 18, 2009 | 12:42 PM
What is the part number at Steele? All I can find in their on-line listings is the small chrome bead, not the wide molding.
Old Jan 18, 2009 | 07:26 PM
442garage's Avatar
Joe, Here you go!Cutlass Convertible With Special Mldg. Standard material. 80-0089-57 $92.50/set
Old Jan 19, 2009 | 10:25 AM
You're right, I skipped right over that. Interesting that they have the convertible but not the hardtop.
Not to doubt your info, but have you actually seen these parts? I'm a little skeptical that the "with special molding" parts are exactly the same price as the non-B85 strips.
Old Jan 19, 2009 | 11:05 AM
442garage's Avatar
Joe, I have not seen these, however, my car has the B 85 moulding and I purchased my window sweeps from Year One. Their catalog lists these as RF406 A coupe, and RF 408 A convertible for 76.00 each and I know from personal experience that these work.
Les
Old Jan 19, 2009 | 02:28 PM
Les
Great, thanks again for the info.
Old Feb 6, 2009 | 08:32 PM
ijasond's Avatar
Purveyor of Polyurethane
restorationspecialties.com
the website and catalog are hard to navigate, but call and talk to the guy. He knows his stuff and has been able to get me belt line kits that no one else could.
Old Feb 7, 2009 | 05:39 AM
Ranzan's Avatar
Getting There
Hey that`s great to hear I have been wondering where I`d be able to find these............
andrewk94
Jul 15, 2013 12:38 PM
67 Olds 442
Apr 13, 2012 07:03 PM
covertolds
Mar 8, 2011 04:41 AM
vagent
Dec 7, 2010 03:00 PM
The_Jeremiah
Nov 15, 2007 06:42 AM
