This is a correctly documented by the Protecto Plate 67 442, it is a 2 door hardtop "Holiday Coupe" with the correct 400E block and the head number matches that Protecto plate, original Sacramento California car, options are: power steering, am radio, heater, bucket seats, console, th400, 3:08 positraction rear end, rally 1 wheels (all 5 are here), very original car, Y code saffron yellow but has been repainted a different yellow. The paint job was not the best and it appears the car was not completely reassembled after the paint. Back bumper is off but have it, wheel well trim is all here but all have some dings, mirror is off but is here, wrong headlight bezels, correct TH400, Correct rearend, Correct engine and heads with correct matching head code engine is very clean outside and has been painted Gold not bronze, and the heads have been switched from side to side. All very typical of a rebuild. It turns over and I have not spent time to get it running. The guy I bought it from said he was driving it about 3-4 years ago. It has not been started since. So, should have some preparations done prior to start up. Brakes work but not great, I find no rot in this car, the right quarter has a repair up high on the quarter that could be done better, there is a paint lifting spot on the hood too. otherwise a very nice body, no trunk or trunk or quarter rot, no rocker rot or fender or door rot,
It is being sold as is here in Redmond, Oregon.
$15,000
Shows a 455 Olds motor not a 400. Still a good deal at 15K.
Actually, that's an "E". 390925 E to be exact (you can see the ...25 E in the photo). A 455 would be a 396021 F, so you'd be looking at ...21 F in that photo.
