1967 442
Old Feb 25, 2021 | 02:06 PM
pettrix's Avatar
1967 442
Not mine:
https://www.oldsmobilecentral.com/fo...442-Fenton.php
$112,500
Old Feb 25, 2021 | 03:29 PM
Weezer's Avatar
Jeff
"South Fenton"? No such town. I live about 10 minutes from Fenton.
Old Feb 25, 2021 | 05:12 PM
Rocketguy's Avatar
https://flagstaff.craigslist.org/cto...273292159.html
Old Feb 25, 2021 | 05:37 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I find it a little interesting he would list a car like this on craigslist.
Old Feb 25, 2021 | 05:48 PM
Rocketguy's Avatar
The car has been for sale for some time.
Old Feb 25, 2021 | 06:20 PM
Heavy duty cooling came with a shroud with the clutch fan.
Oil pans are block color, not chassis black.
No 1967 W-30 came with D heads.
No picture of cowl tag showing that the car is a 442 and in the right date range to be a W-30
Red fenders are too bright to be original (or they're truly beautiful)
I think that's a Chevy rear, not a P rear like the W-30s had.
Radiator top plate and oil tube are not chromed (Oil cap is) on W-30. Is the alternator bracket chromed too?
Battery setup looks off in the back.
No picture of transmission tag.
Column shifted race car?
Old Feb 26, 2021 | 09:06 AM
Kennybill's Avatar
She's got a lot of "sentimental" value.
Old Feb 26, 2021 | 09:58 AM
Yeah, why not? If your AT is properly built and calibrated, you'll likely do better in DRIVE - or at a minimum you'll be more consistent. Keep in mind that if you ordered the optional automatic, you got a column shifter unless you also ordered the console.
Old Feb 26, 2021 | 11:51 AM
/screenshotting post for next time Padavano calls my 442's bench and column AT a "granny drive."
Old Feb 26, 2021 | 01:43 PM
When have I ever said that? Frankly, I've never even heard that term until just now. My SM465 truck has a "granny gear" low, but obviously not the same thing.
Old Feb 26, 2021 | 02:42 PM
Run to Rund's Avatar
Hey, does my Jerico 3.08 first gear qualify as a granny low?
Old Feb 26, 2021 | 02:45 PM
Only if you're the little old lady from Pasadena.
Heck, SECOND gear in the SM465 is 3.58. First is 6.55. I can get out and walk next to the truck in low (the rear end is 4.10).
Old Feb 26, 2021 | 03:11 PM
https://classicoldsmobile.com/forums...3/#post1097194
Old Feb 26, 2021 | 03:16 PM
Damn, you're good.
Old Feb 26, 2021 | 04:13 PM
cherokeepeople's Avatar
that does look like a chevy 10 bolt.
shiftbyear
Jul 8, 2021 06:02 AM
rickman
Jun 7, 2020 04:26 PM
axle1320
Jun 5, 2020 09:33 PM
Kwish
Jan 8, 2010 03:23 PM
