Bucket Seat Swap vs Bench seat boot
Old May 22nd, 2018, 12:06 AM
GoodOldsGuyDougie's Avatar
Hello, I have a friend who is changing his bench seat in his 69 Cutlass S over to buckets. He has a pair of original buckets from I think a 70 Cutlass. I will be doing all the work for him and have never had to do this kind a of swap before. I believe the buckets and how they mount are all the same from 69-72 correct? . The Bucket seats are complete with frame rails etc.. What I don't know about is the mount/brackets on the floor board for the buckets vs the Bench?. Will I have to make 4 new mounts for the bucket seat bracket to bolt too? Or is it just the front inside that takes the small mount/brackets? Can I use the 2 mounts for the bench that are already there and add 2 new ones on the inside?? He also has of course the original carpet for a bench seat car. Will we have to change the carpet out? I have access to several Olds Cutlass's so can I take the floor mounts off the floor on one of those or are they welded as I presume they are to the floor? Or is it best to get the mounts through after market. Thanks in advance for any and all info.
GoodOldsGuyDougie is offline
Old May 22nd, 2018, 04:31 AM
toymobile's Avatar
The bench seat mounts are the same for bucket, need to add the inner mounts,
I have a floor shift tilt steering column if he has a need for that, let me know.
Johnny
toymobile is offline
Old May 22nd, 2018, 06:09 AM
All 1966-72 are the same. The mounting brackets are the same as for a Chevelle. EVERYBODY sells repros. They must be welded to the floor pan. Here is a how-to article.
joe_padavano is offline
Old May 22nd, 2018, 06:55 AM
My 442 has a column shift auto and a bench seat, and someday it will be the only one that way.
Koda is offline
Old May 22nd, 2018, 07:27 AM
Randy C.
rcorrigan5's Avatar
Same for me, Koda! Someday we'll have the only TWO like that!
Randy C.
rcorrigan5 is offline
Old May 22nd, 2018, 07:40 AM
Thank you pal that will do just fine.
Old May 22nd, 2018, 08:30 AM
Sorry, but a bench seat with a column shift AT is a grandma car.
Now, a bench seat with a four speed is cool!
Old May 22nd, 2018, 08:53 AM
lemoldsnut's Avatar
actually if you have a bench seat and a 4 speed she can slide over and you have the best of all worlds
lemoldsnut is offline
Old May 22nd, 2018, 05:49 PM
Floor shifted automatics are compensating poseurs and I'm not converting the car to stick. I own three column shifted automatics, one five speed standard transmission, and one 73 Ford Econoline Club Wagon with column shifted 3 speed standard transmission, and IT has bucket seats for the very good reason of there being a Ford 302 in between them.
Edit: I'm 6'4". I do not need my nooky in the back seat of my two A bodies with bench and column automatic when getting it in the front seat is JUST FINE, thank you!
Koda is offline
Old May 22nd, 2018, 06:08 PM
I've been toying putting an automatic floor shift with my bench seat.
oldcutlass is online now
Old May 22nd, 2018, 06:14 PM
The H/O has a dual gate because it has to. The two 1985s ARE grandma cars. The Vista keeps a column shifted AT because it's a wagon. The rest either already are manual trans or will become so.
Hurst Indy Matic...
Old May 22nd, 2018, 06:20 PM
No respect unless you have a 3 on the tree, Padavano!
Edit: My Tahoe has a column shift because that's all they had. My grandfather ordered the 72 Monte the way he wanted it, and I'm not changing.
The 67 442 has a switch pitch TH-400, which is just cool, so I want to keep it.
Koda is offline
Old May 22nd, 2018, 06:25 PM
I don't disagree. I wish I had the 65 F85 club coupe that my dad bought new from Gallo Olds in Worcester, MA. V6 and three on the tree.
Old May 23rd, 2018, 08:15 AM
MichiDan's Avatar
Good answer here to a question I had not asked yet.
I've been casually shopping for a cutlass for the wife. However it's occurred to me that a bench seat car may be a real problem. She's 5'0" and if she's driving that means I'll be mashed into the glove box. Converting to buckets would be a must.
So not always done for the cool factor I guess.
MichiDan is offline
Old March 16th, 2019, 05:39 AM
1968 442 Convertible
bry593's Avatar
Adding detailed instructions link for those of us needing to add bucket seat brackets:
http://www.buickperformanceclub.com/buckconsole.htm
bry593 is offline
Old March 16th, 2019, 07:04 AM
Gary
VC455's Avatar
To replace a power bench, the outer mountings must be changed. As Johnny said, inner mounts need to be added for buckets--these are the same for power and non-power buckets.
VC455 is online now
Old March 16th, 2019, 07:05 AM
'67 Delmont Convertible
imcgm's Avatar
once you have made a car UNoriginal, you cannot UNDO that. the older i get the more appreciate that fact. that is why survivor cars are going for such big bucks, as nice as you might make a "frame off" restoration you simply cannot restore original.
imcgm is offline
Old March 16th, 2019, 08:00 AM
bry593's Avatar
Couldn't agree more. Unfortunately, my bench is gone and I bought the car with bucket installed, but only fastened at rocker sides. I either have to add brackets or find a bench. I do like the open feeling of the buckets, especially in a convertible.
bry593 is offline
Old March 17th, 2019, 08:13 AM
zeeke's Avatar
Talking
Yea Baby! Granny cars rule. Not only is mine staying a column shift but I'll be installing the tilt column shift I picked up a while back soon and a power bench option.
My friend that passed had a green 66' Belvedere with a column shift plaid tan interior numbers matching 426 Hemi. Now that's one heck of a church goer. He sold it to someone in Australia about 8 years ago. Guess he had that same outlook. He build a 69' GTX Hemi 4 speed, Hemi car non numbers matching and was almost done with a 68' GTX Hemi 4 speed, Hemi car non numbers matching. I should have went in the body business like him, I'd have a whole tribe of Oldsmobiles now.
zeeke is offline
edzolz
December 1st, 2019 05:51 AM
RonFX
October 1st, 2014 05:37 PM
1968CutlassSupreme
January 31st, 2014 06:26 PM
67BB
February 11th, 2013 09:41 AM
Bluevista
February 13th, 2011 03:00 PM
Quick Reply: Bucket Seat Swap vs Bench seat boot
