1970 Cutlass Post 442??
Old Dec 23, 2020 | 07:11 PM
1970supremevert's Avatar
I didn't know 442 was available in a post car ??
not mine
2500.00
FB
https://www.facebook.com/marketplace...code=undefined
Old Dec 24, 2020 | 01:15 AM
OLDSter Ralph's Avatar
Absolutely they were.
Old Dec 24, 2020 | 05:55 AM
The 4477 Fisher Body Code pretty much proves it.
Of course, so do these pages from dealer literature.
Old Dec 24, 2020 | 07:08 AM
fast eddie's Avatar
Guest
Had to have been one of the last ones built... second week of July is pretty late.
Old Dec 24, 2020 | 09:41 AM
As also evidenced by the high Fisher Body sequence number.
Old Dec 24, 2020 | 10:21 AM
Cosmic Charlie's Avatar
interesting that the Sport post cars retained the door vent windows both in 69 & 70.
I see some 71 & 72 Sport coupes Cutlass images online so it carried through 72 with vent windows ? can say I have not seen any of those that I remember ...
so the 68 Holiday coupe was the last Holiday with vent windows ? I have seen a few posts here that they prefer the 68 with the vent windows (so they must prefer the Holiday look as well) ?
were those sport post coupes unique to a certain assembly plant (with so few made) as a carry over thing ? or just made everywhere ?
I have seen a 69 Pontiac Tempest with the vent windows as well ... so the other GM Divisions were all in suit ?
Old Dec 24, 2020 | 10:28 AM
Post cars (Sport Coupes, Town Sedans, and wagons) and four door hardtops had vent windows through the 1972 model year. Dashboards on vent window cars without A/C had no vents in them at all - not even the fake vents used on the hardtops. Olds built a lot more cars than just 2dr hardtops and convertibles.
Old Dec 25, 2020 | 06:51 AM
69CSHC's Avatar
They are actually the most desirable when it comes to original muscle and its primary intent. There the strongest and lightest versions which makes them the quickest and safest...
Old Dec 25, 2020 | 07:07 AM
Sorry, that's a myth fostered by the auction community who tries to pump up every possible variation as "rare" and thus somehow "valuable". The differences between Sport Coupes and Holiday Coupes in both weight and stiffness is nearly negligible. Post cars were low-rent loss leaders. They are rare because they were unpopular when new. Racers took to them more for the lower purchase cost and the fact that they tended to be stripped bottom-feeder cars, so less stuff to rip out when building a race car. The only structural differences between a Sport Coupe and a Holiday coupe are the B-pillars, which are just spot-welded on. Given that the body is rubber mounted to the frame anyway, the stiffness difference is negligible, and any roll cage you weld in provides an order of magnitude more stiffness anyway. The weight difference was negligible - for a 1970 442, curb weight for a Sport Coupe was 3771 lb; for a Holiday Coupe it was 3817 lb. Weights for both cars are base equipment (455, HD 3spd manual trans, 3.08 axle, bucket seats, no console, no A/C, base tires, steel wheels, etc). That 46 lbs is a little over 1% difference, and most of that was in things like simpler window cranks for the post car since the window frames guided the glass. MSRP on that 442 Sport Coupe was $3312. On the Holiday Coupe it was $3376.
Old Dec 25, 2020 | 04:19 PM
Stefano's Avatar
Some Post Coupes, 442s were loaded with options.
Old Dec 25, 2020 | 05:22 PM
Even F85s could be loaded with options. I'm talking about BASE equipment, which is what is included in the curb and shipping weights. And the examples I posted above are both 442s with exactly the same equipment. One typically isn't going to pay extra for a boatload of power options if you just plan to strip them out for a race car, unless you are trying to hit a specific class weight break. Unlike cars today, in the 60s most cars didn't get loaded up with PW, PS, PTrunk, A/C, or all the other stuff that slowed us down.
Old Dec 25, 2020 | 05:57 PM
1of1442's Avatar
442 Sport Coupe
I had the build sheets for mine that showed the column shift M40,Vinyl top, tinted glass, lighting package, power disc brakes,and 3:42 anti spin limited slip.
Circa 1984
Old Dec 25, 2020 | 08:52 PM
"Miraculously", the 2 door (post) coupe (I think shipping weight) weight divided by "factory (listed) horsepower" was right at the top of the class, based on power to weight range in NHRA. This also affected car Insurance rates. Example: (1970 W-30) 3707 lbs / 370 = 10.0189 pounds per horsepower.
Old Dec 26, 2020 | 06:07 AM
Yup. That's a whole different issue, of course - how much HP did the W-30 REALLY make? As I've said before, why would Olds waste the time and money to cast up unique heads, intake, and use a more radical cam and ignition timing to make 30 HP LESS than the W34 Toronado motor that DID come with power brakes and A/C?
Old Dec 26, 2020 | 06:54 AM
69CSHC's Avatar
Yes and no in my opinion. While I get trying to maximize a sale, you cant deny some like a 1966 W30 post coupe are extremely valuable.
But that's just it Joe, if you wanted a quick 442 you wanted it raw and lighter... I will concede that started really going out the window around 1970 because cars were so powerful they could more easily afford the extra weight from options etc... Much like todays performance cars...
But no matter what, put your 69 H/Os powertrain in a 66 post coupe and it will be quicker than any factory stock Olds ever.
You've been saying this for decades and have been proven correct. Horsepower Hijinks article confirms your suspicions. The W34 was overrated by 32 HP. As well as the stick 1970 W30 making more power than advertised.
Orlando 1
May 15, 2021 11:20 PM
WTHIRTY1
Dec 25, 2020 02:38 AM
shiftbyear
Nov 10, 2017 07:33 AM
oldsmobilty
Sep 7, 2014 08:47 AM
