1962 Jetfire $3500
Old Nov 13, 2020 | 09:43 AM
joe10's Avatar
1962 Jetfire $3500
This 62 Jetfire sat it an eastern Washington field since 1989 . The body is straight/original, and I think I have almost every original part as pictured. There is rust in the floor boards as well as one corner of the trunk, but the rest looks surprisingly solid. The Turbo has long been removed and replaced with the 4 barrel intake and GM Rochester 4 barrel (not sure if this was a dealer swap or not?). The motor (code below) turns over, and I actually ran it (after oil bathing the pistons) for a few seconds. One of the cylinders (#2) has no compression unless oil is added, and I believe it is due to stuck rings, which may loosen up with more soaking and longer run time. I am not sure of the tranny condition, but it did pump fluid all over my garage floor during my short run as the radiator cooling lines were disconnected (nice planning on my part). I also have the original Turbo exhaust manifolds, extra heads, intake and various other parts. I am including several pictures below. This was going to be my retirement project, but plans have changed. Let me know if you have interest. Car is located in Washington State and is titled.Engine Code: HI254308
Body Plate info
05A Lansing Michigan
Style: 62-3147 BodyLA 260
Trim 971 Paint V-1 (Charriot Red)
Old Nov 13, 2020 | 11:02 AM
That car is originally from Chicago. The trunk badge is worth something to fans of that dealer, I have a car from the same place.
Old Nov 13, 2020 | 11:13 AM
bronze66f85's Avatar
Actually it is from Oak Lawn IL a suburb of Chicago.
Old Nov 13, 2020 | 12:11 PM
Hairy Olds's Avatar
Shoveling Snow
Old Nov 14, 2020 | 07:28 AM
joe10's Avatar
Nice Badge! I love the way those look on the car.
Joe
Old Dec 29, 2020 | 08:35 PM
2093138A's Avatar
Do you still have this? I’m interested in it please leave a number or contact me at 214-435-6890 or ncuevas7991@yahoo.com
Old Jan 20, 2022 | 03:30 PM
young olds's Avatar
It appears this car is near me now, Idk the new owner but a local body shop owner sent me a couple pictures of it.
v8al
May 2, 2020 05:50 AM
jensenracing77
Apr 8, 2019 10:09 PM
tailfins
Jan 1, 2019 12:00 PM
2093138A
Jan 24, 2017 06:40 PM
intautogroup
Jan 16, 2016 08:51 AM
