1971 442 w30 canadian docs
Old Jan 27, 2021 | 07:18 PM
doctoroldsw30's Avatar
Dr Olds Restoration World
1971 Olds 442 W30
VIN 344871M161175
Cowl Tag
ST71 344 87 LAN 322 812 BDY
TR 930 62 62 PNT
03A (March first week)
Canadian GM Vintage Vehicle Services Inc. Documentation to authenticate the W-30 option.
The car was sold new at Ken McDonald Chevrolet Oldsmobile Ltd. Taber Alberta Canada.
Bittersweet special factory order color. The car was painted an incorrect shade in the 1980’s.
Engine is numbers correct from a Canadian 1971 Oldsmobile 442 W-30 sold new in Edmonton Alberta.
Transmission is numbers matching and original to car.
Differential is correct from a 1971 Oldsmobile 442 W-30.
Black Interior with buckets, floor console and Hurst Dual Gate Shifter.
No rear spoiler.
The car was a running driving functioning car upon purchase. Currently the front fenders, core support, engine, transmission, seats, carpet, dash and console have been removed for cleaning, inspection and restoration.
The car is in Cochrane Alberta Canada. It took over 6 years of knowing the right people and having good luck to acquire all the correct and or NOS parts for the W-Machine.
1-403-651-0428
brentnagy80@gmail.com
Price: $27,000.00 USD O.B.O.
I have 9 zip folders of organized detailed pictures of everything I have restored, all NOS parts etc.
Old Jan 27, 2021 | 07:20 PM
Old Jan 27, 2021 | 07:22 PM
Old Jan 27, 2021 | 07:24 PM
Engine:
Engine has not been rebuilt and is sitting on a stand
F Block, Date Code #5, ID Code F, Casting #396021 from another 71 W30 Canadian Car
H heads Casting #409160 from the same 71 W30 Canadian Car (VALUED AT $5000 USD)
Valve Covers correct “notched” have been restored and painted correct Oldsmobile blue
Oil Pan from the same 71 W30 Canadian Car
Oil Fill Tube OEM GM 1352722 from the same 71 W30 Canadian Car
Oil Fill Cap NOS
OAI air cleaner base, flapper assembly, solenoid, tubes and hold down springs GM new reproduction
Aluminum Intake Manifold “OLDS W-455” original to the car
Intake Manifold Ported Vacuum Switch NOS AC Delco 410052
Thermostat Housing NOS 409038 have been restored and painted correct Oldsmobile blue
Carburetor 7041257 automatic. Rebuilt and detailed by Bob Stone “The Carb Doctor”
Distributor 1112034 automatic from the same 71 W30 Canadian Car
Distributor Cap NOS AC Delco D308R
Distributor Rotor NOS AC Delco D426R
Distributor Contact Condenser NOS AC Delco D1007
Distributor Vacuum Advance NOS AC Delco 407-24
Alternator Delco Remy Open Face period correct no stampings with correct Zinc plated 11 blade fan with “hook” on one blade, correct Zinc plated pulley and Delco Rotor NOS D3153 completely restored
Alternator Brackets completely restored.
Oil Pressure Sending Unit correct new reproduction
Temperature Sending Unit correct new reproduction
Starter Delco Remy OEM 1108387 with correct date code 1B10 completely restored
Master Cylinder OEM Code BE Julian Date 364, Rebuilt with SS sleeve, Delco lid gold cadmium plated
Water Pump NOS AC Delco 408329 “X”
Power Steering Pump Saginaw original to car not restored
Power Steering Brackets completely restored
Steering Box Saginaw original to car not restored
Fuel Pump NOS AC Delco 40711
Fuel Filter NOS AC Delco GF 432
Fuel Sending Unit NOS AC Delco 19179690
Fan Blade OEM 6 blade, 19.5 inch, 740 Ink Stamp completely restored
Fan Clutch OEM 4974367, Delco Prod Division GMC, Letter Code OS, Dayton Ohio Stamp
Wiper Motor Assembly new reproduction
Steering Column Coupler Rag Joint OEM GM 7818568 completely restored
Battery Tray Large and clamp new reproduction
Underhood lamp NOS GM
Mondello Ceramic Coated Headers Model HD34F 3.5 inch with 2.5 inch collectors new unused
Pypes trumpet tips pair new unused
Old Jan 27, 2021 | 07:25 PM
Transmission:
Transmission TH 400 Code OW original matching VIN to the car, needs freshening up
Transmission TH 400 oil pan NOS GM
Transmission TH 400 modulator large Canada version OEM GM
Transmission Torque Converter Cover NOS GM 403703
Transmission Down-Shift switch NOS GM 1242101
Transmission Speedo Drive NOS GM 1362294
Transmission Cross Member is fully restored with Eastwood paint
Driveshaft is one-piece aftermarket completely restored with Eastwood paint and new Moog U-Joints
Shifter:
Hurst Dual Gate completely rebuilt, painted, new top plate, light housing, re-chromed handle, new ball
Hurst Dual Gate shifter cable NOS GM 406266
Differential:
Olds 10 Bolt TM Code 3:42 posi-traction. Currently painted black. Rear drums but no rear pads included.
W-27 Aluminum Cover new reproduction
Wheels:
SS-II 14x7 wheels x 4 original to car in fair condition will require blasting and Argent Grey Paint
Shocks:
Shocks missing. Recommend Bilstein Heavy Duty and paint Inline Tube Shock Dove Gray INL 12490
Transmission:
Old Jan 27, 2021 | 07:28 PM
Body:
Quarter Panels all original to car and minimal rust
Front Fenders are original to car and have correct 1971 crumple zones, typical rust on bottom 5 inches
Roof is rust free in excellent condition
Doors are rust free in excellent condition
Floors are rust free in excellent condition
Trunk Floor is good but has a rust hole approx. 3 inches around the area the spare tire rests against
All chrome and stainless is nice
Glass is all nice and no cracks or deep scratches, Windshield excellent condition
OAI Hood original to car. Bottom steel half has issues. Top fiberglass half has no issues. Comes with mint condition original paint 1971 cutlass F85 hood for donation of lower steel half for grafting.
Hood hinges missing. 1969-72 Cutlass hood hinges required
Front Bumper OEM in good condition with no rust or dents
Front Bumper Brackets OEM completely restored
Front Fenders original to car with correct 1971 year crumple zones
Front Fender lower braces new reproduction
Front Red Inner Fender wells with seals correctly stapled on new reproduction
Front Turn Signal Lenses NOS GM
Front Turn Signal Housing OEM completely restored
Front Marker light housings original with back retainers new reproduction
Front Stone Shield NOS GM
Front Headlight Housing NOS GM
Front Headlight Bezels OEM GM in excellent condition
Front Fender Eyebrow Moldings NOS GM
Front Grilles new reproduction
Front T3 headlights new reproduction
Front Sway Bar original to car needs to be stripped and painted forged steel grey color
Core Support 3 core OEM from a 71 Cutlass completely professionally restored
Core Support Air Deflector and seal OEM from a 71 Cutlass
Radiator 3 core rebuilt with correct cap AC RC-15 new reproduction
Radiator 3/4 core top plate new reproduction
OAI hood chrome pins and core support brackets new reproduction
Cowl mesh screen new reproduction
Heater Box and new heater core completely restored with Eastwood paint
Wiper arms Trico OEM original to car
Wiper blades Trico NOS
Wiper linkages and transmission parts OEM completely restored
Intermediate Body wiring harness installed new reproduction
Rear Bumper OEM completely reconditioned to show quality copper and triple chrome
Rear Bumper brackets OEM completely reconditioned
Rear Tail Light Housings OEM completely restored
Rear Tail Light Lenses new reproduction
Rear Tail Light Housing shields new reproduction
Rear Body wiring harness installed new reproduction
Rear Marker light housings original with back retainers new reproduction
Rear Sway Bar missing recommend Inline Tube reproduction
Door Handles new reproduction
Door Glass outer chrome/felt strips correct installed new reproduction
Rear passenger quarter glass new reproduction with new chrome sash
Trunk Weatherstripping new reproduction
Trunk Lock new reproduction
Jack and lug wrench assembly OEM not restored
Fuel Door License Plate Holder NOS GM 410259
Fuel Cap NOS GM
Fuel tank and straps removed. Recommend Spectra CU GM 34 R
Old Jan 27, 2021 | 07:29 PM
Interior:
Rally Sport Steering wheel and Horn button OEM in good condition
Console has been completely reconditioned, H&H appliques, storage section has correct black felt liner
Bucket seats original complete, need foam and covers, plastic backs and head rests good condition
Seat belts original with original date code tags “5 E 71”
Headliner original in good shape, no rips or sagging
Dash pad in excellent condition
Dash has been fully restored with H&H gauge bezel and H&H 71 supreme walnut appliques
Dash Bead molding new reproduction
Dash Glove Box 442 emblem new reproduction
Gauges (Rocket Rally Pac Gauges) have new lenses and LED light bulbs installed
8 Track Player professional reconditioned by Barry’s 8 Track Repair
8 Track Player housing excellent condition with H&H face plate
Door panels original in good condition
Door panels arm rest bases new reproduction
Door panels arm rest base chrome back plate new reproduction
Door panels arm rest pads new reproduction
Door Lock ***** new reproduction
Glass window guides and stabilizers new reproduction
Window Cranks new reproduction
High Beam Switch new reproduction
Emergency Brake assembly completely restored and detailed with NOS GM pad and pull handle
Brake Pedal new reproduction
Accelerator Pedal new reproduction
Rocker panel sill scuff plates “Body By Fisher” correct new reproduction
Rear view mirror with map light completely restored
Dome Light Lens and chrome base new reproduction
Sun Visors correct material and pattern new reproduction
Package Tray correct mesh style with speaker cutouts new reproduction
Kick panels LH/RH black new reproduction
Carpet was removed and thrown out. Recommend Legendary Auto Interiors
Old Jan 27, 2021 | 07:32 PM
Old Jan 27, 2021 | 07:33 PM
Old Jan 27, 2021 | 07:36 PM
Old Jan 27, 2021 | 07:40 PM
Old Jan 27, 2021 | 07:45 PM
Old Jan 27, 2021 | 07:50 PM
Old Jan 27, 2021 | 07:54 PM
Old Jan 27, 2021 | 07:58 PM
Old Jan 27, 2021 | 08:04 PM
Old Jan 27, 2021 | 08:07 PM
Old Jan 27, 2021 | 08:09 PM
Old Jan 27, 2021 | 08:12 PM
Old Jan 27, 2021 | 08:15 PM
Old Jan 27, 2021 | 08:18 PM
Old Jan 27, 2021 | 08:24 PM
Old Jan 27, 2021 | 08:26 PM
Old Jan 27, 2021 | 11:45 PM
Nickyloves442s's Avatar
I just wanted to let everybody know what a great person Brent is. A cousin of mine and I just dealt with Brent on a beautiful 1970 Olds 442 convertible that he had. He is trustworthy easy to deal with, and a Class Act in every way possible. We are completely satisfied with dealing with Brent. I hope that this car goes to a good person. If I could swing it I will try to buy it myself.
Old Jan 28, 2021 | 10:05 AM
steedaq's Avatar
Great start! Would love to get this one myself but just can’t swing it.
Old Jan 28, 2021 | 11:14 AM
asx455's Avatar
Alan Reedy
Love your advertisement and honest description. Top Notch.
Old Jan 28, 2021 | 11:16 AM
Thanks for all the positive comments and messages !
Old Jan 28, 2021 | 07:00 PM
Looks like it will be a beautiful car when done. Nice.
Quick question.
On the fenders are those done? The spacing on the 442 emblems looks spaced incorrectly. Maybe it's just me..
Just questions not jabs. Nice car.
Old Jan 28, 2021 | 07:53 PM
Hello, the VIN and Cowl tag are correct and as it should be.
The car was painted in the late 1980’s and precise correct fender emblem spacing was most likely not a priority.
Thanks !
Old Jan 29, 2021 | 09:19 PM
My apologies. I didn't realize this was a for sale ad when I first read it.
Looks like it is well worth the price with all the awesome parts etc. Car will look great finished.
Old Jan 30, 2021 | 06:58 AM
  #31
oldsmobiledave's Avatar
Good luck with the sale Brent.
Old Feb 1, 2021 | 07:31 AM
  #32
Reduced Price
$26,000
Old Feb 16, 2021 | 05:50 PM
  #33
Sold sold sold
deaddds
Jan 28, 2021 07:27 AM
1957OLDSPARTS
Aug 12, 2020 09:54 PM
Factoryhotrod
Oct 14, 2019 04:45 PM
doctoroldsw30
Aug 14, 2019 09:23 AM
postw30man
Jan 25, 2019 11:11 PM
