1968 Olds 442 $23.5k (not mine)
Not mine. Link as follows:https://houston.craigslist.org/cto/d...346193193.html
"1968 Olds 442, numbers matching 400 engine. 4spd, power steering and power disc brakes (aftermarket). Good quality driver, runs and drives great. Clean blue title in hand."
1968 Oldsmobile 442
condition: good
cylinders: 8 cylinders
drive: rwd
fuel: gas
odometer: 42000
odometer rolled over
paint color: red
title status: clean
transmission: manual
type: convertible
1968 Olds 442, numbers matching 400 engine. 4spd, power steering and power disc brakes (aftermarket). Good quality driver, runs and drives great. Clean blue title in hand. show contact info
Mike
1968 Oldsmobile 442 - $23,500 (Sugar Land)
image 8 of 111968 Oldsmobile 442
condition: good
drive: rwd
fuel: gas
odometer: 42000
paint color: red
title status: clean
type: convertible
Mike
Just curious to see whatever thinks of this? Might be interested in adding a 442 convertible, i've reached out to seller to see if 4 spd is original, is there a VIN on the trans that could confirm if it was numbers matching? Says he added P/S and Power disc brakes, were 442s offered that didn't have these options from the factory? I asked for a pic of the cowl tag as well.
There's a lot that isn't original. 69-72 seats which would indicate a bench to bucket seat swap. The engine bay is an incorrect mess. Disc brakes were most likely added. Fender emblem placement looks like they are correct laterally for the W36 stripe but too low vertically. Missing the dash stripe.
That all being said, as long as it isn't a rusty mess underneath, $23,500 is cheap and well worth the price
Wouldn't 69-72 seats have headrests? WTH is that chain behind the PS pump? Is that the "fix" for the bad GM engine mounts (I didn't think Olds engine mounts suffered from that issue). The rear bumper looks pushed-up in the middle, and the tail lights look a little misaligned. The driver's door looks to be a slightly different shade from the fender/quarter on that side. It'd be nice to see a photo of the trunk or door jambs and w/ the top up. The cowl tag will reveal if the paint color has been changed. But yeah, for the price a decent looking driver (assuming it HAS a top).
Reached out to the seller, he sent me a video of the car running, said "The car is a good driver. No rust, it has a front clip off of a yellow car. I think it was originally green, but there's no fender tag."
I'm assuming the "no fender tag" mean on cowl data plate, but i asked just to clarify. Don't think i'm all that interested if the cowl tag is gone. How significant is it is the cowl tag is gone?
http://www.trimtags.com/ordering.html
Boy the more you look at that car the more it looks slapped together. 24k and you get a universal top radiator hose. You get a chain doing something. The wiring looks super sketchy. Electrical issues can go on and on. Painted resale red. No rust but how much Bondo? Maybe it's just the lighting but that driver's fender looks to be a different red. Emblems in the wrong location. No cowl tag? That sounds like a heavy hit. He said the front clip was yellow and the rest was green? Obviously an aftermarket radiator and master cylinder. Motor looks tired from here. If someone built that car that cared so many things would have been done differently. I could never see dropping that kind of cash for that car. I bet the more you look the more you would find. Did you ask how old the paint job is and if the car was all painted at the same time? Fool and their money though. Hard pass for me
@allyolds68 @no1oldsfan thanks for the input, think i'm just gonna let this one slide on by, with what you all and others are saying, dont think this is the right one for me, i'm sure another will be up for sell eventually.
Thanks.
Thanks.
Thanks.
Thanks.
I personally like this one. It's not much different that the one above though.
https://classicoldsmobile.com/forums...ed-25k-155768/
@allyolds68 I saw that one as well. reached out to him, confirmed he's in Alaska, that'd be quite the shipping fee from alaska to virginia. it does look good though.
Old school engine mount backup / movement limiter. I used that technique for a while way back in the day until I could buy new mounts and get around to installing them. IIRC some Camaros had a recall or campaign through GM that added a similar device made of cable.
