Restored and repainted in the 90’s. All original except the carburetor, fuel pump and wheels. Fun weekend cruiser and restore as you enjoy and drive. Original 400 CID engine, E block, C heads, and TH400 automatic transmission. Lansing built 5V car with protect-plate, power steering, brakes(drums), windows, top (new in ~2020), trunk release (non-functional) as well as AC (non-functional but all there). Original mid-night blue, white top and original light blue interior. Has 14x7 SS1 wheels and low mileage radial tires and I have the original steel wheels and wire hubcaps. Oil, transmission and differential fluids just changed and ready for the road. Located in Western NC - $28K
Depends if you want a show car or a driver. The engine compartment could use some work. Block was painted the incorrect blue at some point and needs to be detailed and painted the correct gold. Interior is all original and has a seam or two that needs fixing. Trunk lid molding and tail lamp surround needs to be repainted black. Has some rust near the rear body mounts and wheel wells. I’ll post some more pictures tonight.
Added a few more pictures. Runs good, leaks a little oil from valve covers. Have new gaskets and new mechanical fuel pump to replace electric pump. Contact me with any questions. Seam needs repair on drivers side. Rust spot in rear wheel well / trunk.
