1964 Cutlass project $3800 OBO
Old Aug 2, 2019 | 01:34 PM
Mike Sundy's Avatar
1964 Cutlass project $3800 OBO - SOLD
1964 Oldsmobile Cutlass 2 door no post project car for sale. This car has a small block V8 from a 1970-71 Oldsmobile. The car is mainly disassembled but all parts related to the car go with it. Title in hand.
The Good:
Completely rebuilt heads done by local machine shop.
New cam, lifters, rods, springs, valves, rockers, spark plugs, timing gears and chain, water pump, and belts.
Rebuilt Holley carb.
Complete wiring harness, new in box.
All glass complete and undamaged.
Wheels are nice but an unknown vintage.
Changed to floor shifter from steering column.
The bad:
Paint job will need to be redone. It is passable from 20ft...rough up close.
The interior needs to be completely done. Comes with two front seats; one needs new foam and they both need to be recovered.
The back seat bottom is in good shape but the top needs to be trimmed as it came from a larger car.
The ugly:
The floor needs to be replaced. I have panels for the rear section.
The drip rails need attention as does the area around the trunk.
This project would be great for someone with welding skills (I don't have them). I found out too late how much welding is required and lost interest in the project. I have sunk at least 7 grand into this project, probably more. My loss is your gain. Price is negotiable. Send me an email to discuss a time to meet if you are interested.
Local pickup in Fitchburg, MA.
Old Aug 2, 2019 | 04:45 PM
oldstata's Avatar
Justin
Good price if it was closer I would grab it!
Honestly the rust repairs pairs you have in the photos are not bad considering, They are nice hides me spots where you could learn how to weld and it wouldn’t need to be perfect, as a bad welder my grinder is my best friend
Old Aug 2, 2019 | 04:58 PM
Mike Sundy's Avatar
Thanks! I'm more of a bolt on and electrical repair guy, but I've gained an appreciation for the skill welders have joining thin sheet metal.
Old Aug 2, 2019 | 05:42 PM
RetroRanger's Avatar
72 Olds CS
hi Mike
I just saw your car on CL. Im in ma too
My floors needed work to I just bought a welder and went at it (no real prior skills)
Mine came out pretty good and like stata said good place to learn as it will be hidden.
Old Aug 2, 2019 | 06:11 PM
If its just the floors, perhaps a buddy with some welding experience could help you out. Like the others said, its a great way to learn in an area that will be covered with carpet. A cutoff wheel, sheet metal screws go a long way to get everything to fit.
Old Aug 2, 2019 | 06:46 PM
oldstata's Avatar
Justin
I had no skills I bondo the crap out of my first hot rod 72 cutlass, my 65 I was guided by a friend but I did 85% of the work on my car except paint,
look up kids helping with projects to see my build
Old Aug 2, 2019 | 08:43 PM
OLDSter Ralph's Avatar
What transmission ? Is it driveable ?
Old Aug 3, 2019 | 07:20 AM
therobski's Avatar
I bought my 64 F85 and it needed floors, trunk pans, the braces for the floors and trunk pan, the section between the tail lights, both doors and left front fender. Bought a Miller-matic 190 welder. Attended a welding class at the local High School and got started. A grinder and seam sealer are you best friends. If I remember correctly if you need to replace both floor braces, one of them requires that you pull the body off. Due to this project I pulled it anyway. Being yours is a Northern car have you had it up on lift and peaked at the frame? Mine was from Michigan and I need some minor frame repair and I reinforced some areas by boxing the frame 3/16 plate steel. Now if I chose not to go that deep into the project would have sold the car.
Old Aug 6, 2019 | 03:13 PM
Mike Sundy's Avatar
That came out very nice. It needs one floor support that comes with the car, the middle one. It is not in a driveable state. I never tuned the engine after rebuild, still has the break in oil in it. Picture of the tranny pan below to help id it.
Old Aug 6, 2019 | 03:36 PM
therobski's Avatar
Someone will buy the car as stated above that has or enjoys sheet metal fabrication and welding. I learned how to make it fun. would I do it again? NO only because I'm going to retire in a year or 2 and will not have the room...
Old Aug 6, 2019 | 05:04 PM
Mike Sundy's Avatar
Fair enough. Wanting to weld is a must for this car.
Old Aug 10, 2019 | 03:06 PM
Mike Sundy's Avatar
Sold to a guy who plans on doing a full resto with a twin turbo Olds diesel. Thanks for all the help!
John Gregory White
Jun 5, 2020 10:24 AM
Btodd34
Apr 22, 2020 10:46 AM
Snakesolds
Apr 21, 2020 10:14 AM
freloncharlo
Sep 13, 2019 12:41 PM
johnbumb@charter.net
Oct 2, 2018 05:43 PM
