Weatherstrip Questions 72 Cutlass Convertible
I am about ready to install a new header seal on the front of my convertible top, as well as the 2 pillar post seals.
Do they all get weatherstrip adhesive?
Is there a good product to remove old, dried out weatherstrip adhesive?
All I did to remove the old weatherstrip adhesive was to scrape it out with a flat-blade screwdriver, being gentle not to gouge the metal or anything. It came up pretty cleanly. Then I wiped all surfaces with a degreaser before applying the adhesive.
I used this stuff, yellow 3M weatherstrip adhesive. Works wonderfully, and 1/4 tube should easily do your job.
I would opt for the black version of that same 3M product - works as well but excess matches the seal.
In removing the old adhesive, scrapers made from scrap CDs (polycarb.) or popsicle sticks work well without gouging paint if you are careful.
Right after installation, freshly dried adhesive can be removed with goo-gone.
Properly applied, you don't see the adhesive, so it really doesn't matter what color it is.
Second, and more helpfully, the weatherstrip itself is black, so using an adhesive with a sharply contrasting color, like yellow, makes it much easier to see what areas of the weatherstrip have had adhesive applied and which haven't as you're spreading it around. In fact, I wonder if this isn't the reason that 3M makes a yellow adhesive at all.
STRETCH1
Jul 28, 2017 05:12 AM
olds70supreme
Oct 16, 2014 05:04 PM
oldsdroptop
Jan 22, 2010 07:39 AM
STRETCH1
Body work
Dec 27, 2009 04:58 AM
