Care and Appearance Washing, waxing, paint care products, etc.
Restoring plastic inner guards
Old Oct 5, 2014 | 10:43 PM
73aussie455's Avatar
Acceleratii maxim rapidus
I've been detailing all the usual under the hood, firewall, brake booster, air cleaner, brackets, hoses etc, and am looking for a solution to restore the finish to the plastic inner guards.
Everything i've tried leaves a dull or patchy finish. I'm not after a concourse result, just a consistent finish.
I've tried; Plexus (plastic cleaner & polish), kitchen cleaner(spray & wipe), Armourall, turps, metho, soapy water and tire shine.
My last resort is to mask it all up and use satin black spray paint. (not ideal)
Any ideas? Thanks.
Old Oct 6, 2014 | 01:02 AM
Yellowstatue's Avatar
If they are clean and all the dirt is off, try a good quality boot polish. However there are other threads here that address this specific problem.
Old Oct 6, 2014 | 01:51 AM
Thanks for that, found the info
Old Oct 12, 2014 | 05:01 PM
jpc647's Avatar
What'd you find out? And how did it turn out.
Old Oct 13, 2014 | 01:23 AM
I found lots of threads on cleaning and restoring engine bay plastics, this is probably one of the best;
https://classicoldsmobile.com/forums...mpartment.html
I really didn't want to paint with SEM or a plastic/vinyl restorer.
Ended up persevering with the same stuff I use on my race bike, PLEXUS plastic protectant, cleaner and polish, made in the US.
http://www.plexusplasticcleaner.com/about.html
Seems to work great, stripped the crud right off and left the original colour. I had to get a little aggressive where the A/C clutch sprayed grease/oil in a line next to the compressor for the last 40 yrs and there are a few abrasions where pipes have been rubbing, but I will leave it as is. Very pleased with the result.
I've used it on all the under hood plastic and external body plastic.
jensenracing77
Jan 9, 2012 06:38 AM
commwog
Oct 15, 2011 08:51 PM
davebw31
Mar 25, 2011 06:55 AM
guycaso
Feb 1, 2011 12:27 PM
72rocket
Jan 13, 2008 02:39 PM
