Care and Appearance Washing, waxing, paint care products, etc.
Remove nicotene from license plates?
Old Dec 13, 2010 | 03:19 PM
ChefDeadpool's Avatar
Okay,
I bought a par of Texas license plates, that the DMV won't approve because they're too yellowed. By the smell of them, I think they're caked with nicotene and dirt. Is there anything I can use to remove that without damaging the plate on the license plate? Furthermore, is there anything else I can use as a whitener so I can just get these things to pass approval?
Old Dec 13, 2010 | 04:27 PM
InfoJunkie's Avatar
InfoJunkie
Try toothpaste or Autosol.
Old Dec 13, 2010 | 04:46 PM
rroth01's Avatar
From: Orion Township Michigan 30 Miles North of the Murder City
Stained plates
Have you tried Wesleys Bleach White?
Works great on white lettered tires .
And it removes road grime.
Ron
Old Dec 13, 2010 | 05:02 PM
Autosol what? Autosol seems to be a brand. Which product?
In the meantime, I'll try toothpaste.
Old Dec 13, 2010 | 07:07 PM
Funkwagon455's Avatar
Talking Tag approval methods
The truth is that these things are regularly slightly yellowed, that is perfectly normal.. If you have more than one DMV in your particular county, it may be worth a try to start over at the alternate location.. The tags are forty years old, and have likely been stored every summer in a garage/attic/shed at a refreshing 108 degrees! Sometimes it seems the gals at the DMV are often trained specifically to be as difficult as possible, or possibly just feel drunk with the power, I hav'nt figured them out. I doubt you will have very much luck whitening the paint. Not to be a pesimist, I just feel as though the good hard work'n folks at the DMV need to be realists! Best of luck!!!!
Heath
Old Dec 13, 2010 | 07:24 PM
InfoJunkie's Avatar
InfoJunkie
Autosol is a metal polish probably available at a local autoparts store.
I saw it on the Jegs website as an Eastwood product. People are always telling me parts are cheaper in the US but that one costs twice as much as what we sell it for at work. I've used Autosol on chrome, plastic and paint. It is just a polishing compound.
Old Dec 14, 2010 | 05:17 AM
Lady72nRob71's Avatar
108 if they were stored outside in TX. In the attic, it would be up to 130* in our summers!
Do you have a picture of your plates?
I have a set which aren't too bad, but look yellow against a white car.
I would like to see if mine are better.. This set I have might be for sale if I pick up a mint set today after work.
If it is really nicotine from ciggies, then rubbing alcohol should take it off.
Old Dec 14, 2010 | 05:56 AM
Oldsguy's Avatar
Past Administrator
X2 for Westley's Bleach White, that stuff is very, very good.
Old Dec 15, 2010 | 04:56 AM
Willidog's Avatar
Official Tire Kicker
Or "Greased Lightning". It's a pretty good cleaner for removing grease and grime, or Goo gone.
dedsleds
Jan 29, 2010 02:53 PM
J-(Chicago)
Sep 17, 2009 05:19 PM
Cut-67
Paint
May 13, 2009 09:13 PM
BAM583
Apr 11, 2009 06:49 PM
RAMBOW
Mar 27, 2009 03:02 PM
