Paint protection film
Hey: hopefully I will doing a long drive this summer through some potentially buggy areas and was wondering if anyone had every used this product:
http://www.empirecovers.com/buy-road-wrap.aspx
Thanks, Peter
Thanks, Peter
Talk to a body shop and have whoever does theirs do yours. Usually they use 3m. The stuff is really good taking it off kinda sucks but it wont harm anything. Although it will actually protect the clear from fading. i have taken the clear bra off a caf and noticed the area that had the film was much more vivid and less faded. There is also a company that sells it in a sprayable form but that is permanent although you could do the whole fender and it would look the same just when you feel it it will feel like rubber somewhat.
Copper: I am avoiding the 3M and similar, "permanent", products because I only want to use it for the couple of days driving through buggy environments. What attracted me to Road Wrap is that it only used for a short period and is supposedly easy to remove.
I looked at Biltrite's Autowrap:
http://www.idealabi.com/content2.aspx?url=p_117.htm
but the smallest roll it comes in is 100M.
Thanks, Peter
Thanks, Peter
Gotcha. Why ot use that plastic dip stuff. Alot of guys are doing whole cars and that stuff is suppoused to peel right off. It does not come in clear but if avoiding rock chips is the issue it might be cheaper to do so with the plasti dip it comes in a bunch of colors . My friend did his bumper on ths silveradi in flat black and it turned out great . The big claim is that it peels right off.
I work in the collision repair industry. I have fixed vandalized cars that have been spray painted. straight spray paint has more solvents in it than plasti dip. all it took to de vadalize the car was buff it and the paint was ot etched or dulled or lifted. Same goes for laquer thinner. you can wipe a car down with laquer thiner to pre prep before a buff. but it you sit there long enough it will lift the paint. Once paint is cured it takes some effort to get the paint to lift.
[QUOTE=pcard;530426]Copper: I am avoiding the 3M and similar, "permanent", products because I only want to use it for the couple of days driving through buggy environments. What attracted me to Road Wrap is that it only used for a short period and is supposedly easy to remove.
I have actually used this product. It worked well. The only problem was where there was an edge that was not properly adhered, the edge flapped in the wind and left a mark on the paint that needed to be buffed out.
Thanks TeCar442. I also found this warning thread on a Vette forum:
http://forums.corvetteforum.com/c6-c...road-wrap.html
Cooper - thanks for that.
Peter
Peter
Curious if anyone has any new opinions on paint protection film since this thread is 5 years old. I have a new paint job and want to keep it rock chip free and am looking at the XCEL and SunTek stuff. Anyone ever install it yourself or is it best to let a pro do it?
I had XPEL installed on the front of my Challenger when I bought it. I drove about 60,000 high-speed miles without any sign of a chip to the paint—or headlights.
I know it has taken some good hits from stones and road trash because the unprotected aluminum surround of the upper grille and the radiator behind both grilles show hits.
In November I had a large portion of the XPEL replaced (operator error). I was concerned that there would be hidden chips that would be removed with the old film. Nada. The paint underneath the film looked pristine.
Because of this great experience, when the Vista Cruiser returns home, I’ll have XPEL put on the paint and front bright-work.
The only negative I can come up with is that the edge of the XPEL is visible because pf the thickness of the film. The film gloss is identical to the paint gloss, so that is not a factor.
Some in the local LX club have put XPEL over the entire front end—back to the windshield and front doors—to eliminate that edge.
creativefilmcars
Cars Wanted
January 10th, 2007 05:59 AM
