Care and Appearance Washing, waxing, paint care products, etc.
Arrggghhh!!! I'm so aggravated right now!!!
Old Nov 3, 2024 | 02:25 PM
72455's Avatar
1972 U code Supreme
For the hour or so I've been trying to get the corner trim and the lower trim piece on my '72 Supreme to line up and have gotten absolutely nowhere!!!
I'm guessing that if I loosen up the speed nut for the corner trim piece, I can tweak it enough to get it lined up. Problem is, IT WON'T LOOSEN UP!!! I've tried every which way I can possibly fathom, and it's not working!!
I don't want to leave it like it is, but I dunno what to do.
Please advise!!
Thanks!
Old Nov 5, 2024 | 03:57 AM
JohnnyBs68S's Avatar
Is it an issue of accessing the speed nuts from the trunk and getting enough torque on it to loosen it? Or is is so rusted-on that it won't budge? If the former, try a 6-point box-end wrench or small 6-pt socket (if there is room). If the later, soak it w/ penetrating lube. Keep in mind that after many years of being clamped in one position that it may have left an impression in the vinyl and be difficult to keep it in a new (better aligned) position as you re-torque the nuts. A 2nd set of hands may be required.
A picture of the inside access to the trouble nuts would be helpful.
Old Nov 5, 2024 | 04:29 AM
72455's Avatar
1972 U code Supreme
Thanks for the reply, but I was able to get it done.
Old Nov 6, 2024 | 05:45 PM
davek1661's Avatar
Please advise!!
Thanks!
Your attention to detail is admirable. Glad you got it worked out- but no "after" picture?
Old Nov 6, 2024 | 05:57 PM
72455's Avatar
1972 U code Supreme
Doh!! Here ya go...
Old Nov 7, 2024 | 08:17 AM
Sweet, nice job.
brotherGood
Care and Appearance
Aug 3, 2024 06:25 PM
72455
Body work
Mar 16, 2022 06:45 PM
LadyMechanic
Dec 24, 2021 10:44 AM
Bitburger
Body work
May 20, 2016 04:46 AM
