SSBC conversion kit a123-1
Old Oct 13, 2012 | 09:49 AM
1971viking's Avatar
Anyone run this kit with vacuum @10 or less when idle? I have tripple checked everything and the car wont stop. The brake pedal feels good just takes a long time to stop the car. I can't get the front wheels to lock up. Rear distribution is on and no lock up in rear.
Is it the vacuum?
Old Oct 13, 2012 | 11:07 AM
oddball's Avatar
That's very low vacuum for a small single diaphram booster. Can try a larger or dual booster.
Even so, should still be able to force through it. Maybe still have some air in the lines? Can be tough to bleed properly with the combo valve.
Old Oct 13, 2012 | 11:42 AM
1971viking's Avatar
Just checked again and the vacuum is @10 in park and @9 in Drive. I had 11inch booster with drum and it worked great. Maybe go back to that or get a electric vacuum pump. The labor and price should be the same either way.
Old Oct 15, 2012 | 07:30 AM
1971viking's Avatar
Going with the SSBC electric vacuum pump and canister. Oh well. Do it right or don't do it.
66ninetyeightls
Ninety-Eight
Mar 12, 2015 07:21 AM
65dynamo
Brakes/Hydraulic Systems
May 19, 2013 10:30 AM
1971viking
Dec 18, 2012 05:22 AM
Toby
Sep 7, 2012 04:55 AM
