Drum to Disc conversion
Old Oct 19, 2012 | 09:34 AM
Rios69Cutty's Avatar
I have a 69 Cutlass Convertible, 350 rocket, 400 trans and i'm thinking about converting the drums to disc. i'm also thinking about just adding a power booster to the master cylinder instead. I'm new to doing restorations and looking for recommendations, should i do the conversion or not and is adding the power booster a good idea or just a waste of time and money?
Old Oct 19, 2012 | 10:16 AM
droptopron's Avatar
delete
Have you driven the car? The choice of power or manual is one of personal choice, assuming your engine doesn't have a very big cam so vacuum is not an issue. Discs are safer than drum because drums don't dissipate heat as well as discs so they'll fade after repeated uses.
Old Oct 19, 2012 | 10:23 AM
RonFX's Avatar
Rios:
I have a 66 cutlass that I did the conversion on, it made a HUGE difference in the car. The manual drum setup was basically a crapshoot in an emergency situation, even though it was in excellent shape w/ new stuff a few years ago. I ordered the kit from OPGI and had NO problems w/ the conversion, it came w/ everything I needed to do the job. The difference was amazing, a major difference in stopping power, money well spent, if you going to keep the car, I would suggest an overhaul on the front suspension at the same time. New BJ's and control arm bushings as well.
Thanks Ron
Old Oct 19, 2012 | 11:17 AM
Eddie Hansen's Avatar
I have a 69 very and I went with a 4 wheel disk brake set up from getdiscbrakes.com the conversion was straight forward and included everything I have not driven mine yet but I know when I decided to go with a 455 I wanted more stopping then. 4 wheel drum
Old Oct 19, 2012 | 02:50 PM
https://classicoldsmobile.com/forums...sk-brakes.html
455Olds
Brakes/Hydraulic Systems
Dec 8, 2013 08:16 PM
sleeton
Nov 5, 2009 01:58 PM
meraul
Oct 24, 2009 11:05 AM
elcaminodave
Aug 9, 2009 04:57 PM
crazyiball
Jan 18, 2007 06:40 PM
