brake pedal soft
Old May 3, 2010 | 11:43 AM
KevinBN7's Avatar
brake pedal soft
My 71 cutlass supreme has been seeing quite a bit of use now that spring is in full swing. Yesterday the brake pedal felt soft so when I got home I opened the master cyl. the front resevior was empty so I have a leak somewhere in the system. Although I havent taken the wheels off I got under the car to see if I could find any obvios leaks. every thing I could see was dry.
My question is the what wheels is the front resevior related to? Is this a diagonal system so is it one front and an opposite rear? I am trying to narrow my search options
The car has 4 wheel drum brakes if it matters
Kevin R
Old May 3, 2010 | 11:57 AM
Kevin R
It is not a diagonal system and the front reservoir should feed the front brakes.
Old May 3, 2010 | 12:59 PM
KevinBN7's Avatar
Joe thank you for the quick response. The front drums are dry however the bottom half of the booster ( under the master) is covered with fluid. I assume this means a new master and bleed brakes.
KR
Old May 4, 2010 | 05:26 AM
You might want to remove the front drums just to make sure the slave cylinders aren't leaking fluid. If your slave cylinders are relatively clean on the front then I would go ahead and replace your MC and bleed the brakes.
BTW, do you have power brakes? If so you might consider replacing your vacuum booster at the same time. I just did a similar job on my 71 98 and it wasn't much more expensive or time consuming to replace the vacuum booster with the MC. Good luck!
hookem horns
Brakes/Hydraulic Systems
Apr 22, 2013 07:27 AM
poorboy_616
Apr 16, 2009 05:45 PM
mcutlass1969
May 31, 2008 04:48 AM
Nailhead 88
Jan 7, 2008 02:07 PM
Oldsproject
Jul 19, 2007 08:45 AM
