68 to 69-72 Drum Brake to Disc Conversation
Old Jul 31, 2023 | 09:02 AM
Cincinnati Rick's Avatar
I posted this in my build thread but didn't get any responses. Hopefully someone has dealt with this before and can help me out.Trying to install the disc brake hoses to the frame but ran into an issue. The 69-72 brackets mounting holes and indexing holes do not line up. Anyone else run into this problem? Do they make a disc brake hose mount with the mounting hole and indexing hole in the correct place or do I need to drill new holes in the frame for the indexing tab to fit in?
Old Jul 31, 2023 | 10:08 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
68-72 drum & disc flex lines, frame brackets and retainers are not interchangeable components.
​​​​​​​You must match all disc brake components...flex lines, brackets, retainers.
The disc brake flex line has different ends on both sides to include the correct hex & key that keys into the frame bracket.
Source 69-72 frame brackets, flex lines & the correct U shaped retainers, and of course the 69-72 caliper & hardware.
Old Jul 31, 2023 | 11:49 AM
I have the correct 69–72-disc brake frame brackets, but the 68-frame is drilled for 68-drum brake brackets. I also have the correct 69-72 flex lines, and calipers. I guess I will need to drill a new hole in the frame for the 69-72 frame bracket indexing tabs. Maybe I'm over thinking this?
Old Jul 31, 2023 | 12:03 PM
The 69-72 brackets are RH/LH. The 68 brackets are the same on both sides. Personally I would either use the 68 brackets (file the hex hole to fit the 69-72 hoses) or grind off the locating tabs on the later brackets and weld on a new tab in the needed location. You can drill the frame, but I'd prefer not to.
Old Jul 31, 2023 | 08:42 PM
I didn't remember having this issue when I did the conversion young n dumb...back in 85 using a 72 Cutlass doner car.
So I just crawled under it to verify. I think I simply heated and bent the 72s keying tabs flush. Then tighten it up with the metal line and the factory fastener holding it in position. Hasn't moved in 38 years. The soft lines were replaced 20 yrs ago, dam time flies. Prob due again.
Not saying this mod is 100% as I normally do things but....it works. I wasn't 100% back then either...still not.
I think the hard-line geometry may/could be slightly different on 68 drum vs disc. I see the locating hole in the frame just above the bracket towards the front, unless the bracket geometry is that different, Coundnt get under it far enough to operate the cam & light.
Again it works safely.
matt69olds
Suspension & Handling
Feb 27, 2023 01:44 PM
Mocephus
Oct 1, 2021 09:45 AM
cruzn4evr
Nov 2, 2020 12:41 PM
Maverick
Brakes/Hydraulic Systems
Jun 26, 2013 08:21 AM
68conv455
Nov 13, 2008 08:57 AM
