Help..no pressure to rear brakes
Old September 26th, 2009, 12:02 PM
ctrain22's Avatar
I purchased a disc brake conversion kit for my 68. It actually had disc brakes originally, but some bonehead took out the whole system before I got it. I put the system in and the front brakes work fine, but I am not getting pressure to the rears. The kit included master, booster, calipers, and proportioning valve. I got another master, thinking I got a defective one in the kit, but still no pressure to the back. Any suggestions would be appreciated. Could it be the proportioning valve?
ctrain22 is offline
Old September 26th, 2009, 12:38 PM
Registered
Bluevista's Avatar
It could be that the valve isn't centered, does the brake warning light on the dash work/come on?
Go to test combination/proportioning valve in this link and it says what to do if it is the valve.
http://www.classicperform.com/TechBo...oubleshoot.htm
Bluevista is offline
Old September 26th, 2009, 01:57 PM
ctrain22's Avatar
Thanks blue, this will help. Hopefully it will work.
ctrain22 is offline
72allblackcoupe
April 6th, 2014 07:20 PM
foreverolds
December 1st, 2012 07:07 PM
1carsick
Brakes/Hydraulic Systems
23
October 2nd, 2012 05:50 PM
russell-t
April 30th, 2011 05:56 AM
Kidcutty
May 1st, 2010 11:58 AM
Quick Reply: Help..no pressure to rear brakes
