2" brake shoe for 2.5" rear drum? 1969, ninety-eight
I have been on usual sources, CarID, Kanters, local chain stores etc, to buy replacement parts for my 98. They are all showing a 2" X 11 brake shoe for the rear brake, but that is actually a 2.5" drum. I assume a 2" could be used, but I can think of a couple of reasons to prefer a 2.5" as spec'd. The only source I can find for a 2.5" shoe is O'Reilly house brand Brakebest (bonded) or NOS on e-bay which I suspect are rebuilds. NO problem finding the 2.75 X 11 for the front.
Why not use the O'Reilly's shoes? Is bonded the concern?
That is where I am leaning, but I have looked at opinions on these and they are all pretty lukewarm to negative. Might be my only option. This is a restoration of grandpa's old car and not a daily driver, so I need to keep that in mind.
Maybe bonded shoes could be relined as riveted by drilling holes? If yes, get the bonded and when they are worn have them relined as riveted. FWIW I'd get the bonded now and see how they last.
As maintenance check the brake lining regularly to protect the unobtainium old school drums.
Those brake shoes are *** N O T *** made by anyone / any outlet in the Chineseum world ---
and that is a Very Good circumstance for you---- because you wouldn't want that garbage, IF there was such a thing........
What you *** ONLY *** WANT *** is *** N.O.S. Asbestos *** for Nice Smoooooooth braking and not ripping up those very expensive Brake Drums to smithereens......
I have those Rear Brake Shoes --- 11 " x 2 1/2 " indeed --- for the 1965 - 1969 OLDS 98 --- Rear
ALL --- ONLY ----.......
Always best to simply call me --- 516 - 485 - 1935 ...... Craig ......
Unless it is a mistake Carquest / Advance shows them in stock at my local store. Part number S261.
11 x 2 1/2 Cant tell by the picture if they are bonded or riveted but I don't see what difference it makes personally. I have never had an issue with bonded shoes. They also show the 11 x 2 as part number S262 They show the fronts as part number S260 but do not have them.
I can get the S260 (2.75") and the S272 (2"), but no S262 or S261 option. Might be a regional thing. I will probably just get the brakebest.
As mentioned above O'Reilly Auto has them. 11" x 2.5" (bonded).
I think you are better off having the right sized brake shoes (11" x 2.5" bonded) rather than 11" x 2" riveted.
Any luck finding breaks, or did you use the 2 inch? I’m looking for 2.5 inch.
