2" brake shoe for 2.5" rear drum? 1969, ninety-eight
Old Aug 12, 2022 | 05:53 AM
nickwisconsin's Avatar
I have been on usual sources, CarID, Kanters, local chain stores etc, to buy replacement parts for my 98. They are all showing a 2" X 11 brake shoe for the rear brake, but that is actually a 2.5" drum. I assume a 2" could be used, but I can think of a couple of reasons to prefer a 2.5" as spec'd. The only source I can find for a 2.5" shoe is O'Reilly house brand Brakebest (bonded) or NOS on e-bay which I suspect are rebuilds. NO problem finding the 2.75 X 11 for the front.
Does anyone have a recommendation or source?
Old Aug 12, 2022 | 06:13 AM
Hairy Olds's Avatar
Shoveling Snow
If you have your old shoes have them relined. There are places here in WI that rivet material you old shoes.
Old Aug 12, 2022 | 06:39 AM
The old shoes are in horrible shape. If I sandblast the rust, there wont be much left to line.
Old Aug 12, 2022 | 07:10 AM
Sugar Bear's Avatar
Why not use the O'Reilly's shoes? Is bonded the concern?
Old Aug 12, 2022 | 07:33 AM
That is where I am leaning, but I have looked at opinions on these and they are all pretty lukewarm to negative. Might be my only option. This is a restoration of grandpa's old car and not a daily driver, so I need to keep that in mind.
Old Aug 12, 2022 | 07:56 AM
Oldsmaniac's Avatar
Rockauto?
Old Aug 12, 2022 | 08:00 AM
Rockauto?
No 2.5". Just 2" and 2.75"
Old Aug 12, 2022 | 08:03 AM
Sugar Bear's Avatar
Maybe bonded shoes could be relined as riveted by drilling holes? If yes, get the bonded and when they are worn have them relined as riveted. FWIW I'd get the bonded now and see how they last.
As maintenance check the brake lining regularly to protect the unobtainium old school drums.
Good luck!!!
Old Aug 17, 2022 | 06:03 PM
mpolds's Avatar
Those brake shoes are *** N O T *** made by anyone / any outlet in the Chineseum world ---
and that is a Very Good circumstance for you---- because you wouldn't want that garbage, IF there was such a thing........
What you *** ONLY *** WANT *** is *** N.O.S. Asbestos *** for Nice Smoooooooth braking and not ripping up those very expensive Brake Drums to smithereens......
I have those Rear Brake Shoes --- 11 " x 2 1/2 " indeed --- for the 1965 - 1969 OLDS 98 --- Rear
ALL --- ONLY ----.......
Always best to simply call me --- 516 - 485 - 1935 ...... Craig ......
Old Aug 18, 2022 | 07:13 PM
mpolds's Avatar
Hey Nick from Wisconsin ---- you alive out there ????
Old Aug 19, 2022 | 06:22 AM
Minibike Mark's Avatar
Where in WI are you? I'm parting out a 1968 98 and may have what you need.
Old Aug 22, 2022 | 08:02 PM
Last time I checked. Do you have the 2.75" for the front as well?
Old Aug 22, 2022 | 08:41 PM
66SportCoupe's Avatar
Pretty. Generic shoe. Don't go under the 2.5 width
Old Aug 23, 2022 | 05:55 AM
Unfortunately it isn't. Brake parts for the 65-70 full size cars are tough to find these days.
Old Aug 24, 2022 | 10:15 AM
BillK's Avatar
Unless it is a mistake Carquest / Advance shows them in stock at my local store. Part number S261.
11 x 2 1/2 Cant tell by the picture if they are bonded or riveted but I don't see what difference it makes personally. I have never had an issue with bonded shoes. They also show the 11 x 2 as part number S262 They show the fronts as part number S260 but do not have them.
Old Aug 24, 2022 | 10:45 AM
I can get the S260 (2.75") and the S272 (2"), but no S262 or S261 option. Might be a regional thing. I will probably just get the brakebest.
Old Aug 24, 2022 | 10:47 AM
BillK's Avatar
I wouldnt be a bit surprised if they are not the same thing
Old Aug 24, 2022 | 10:50 AM
I think you are right. The pictures look identical
Old Aug 24, 2022 | 01:25 PM
That's the same result I get when I search.
Old Aug 24, 2022 | 02:35 PM
v8al's Avatar
Registered Olds Owner
As mentioned above O'Reilly Auto has them. 11" x 2.5" (bonded).
I think you are better off having the right sized brake shoes (11" x 2.5" bonded) rather than 11" x 2" riveted.
https://www.oreillyauto.com/shop/b/b...?q=brake+shoes
Old Aug 24, 2022 | 02:57 PM
Autozone also claims to have #261 shoes available.
Old Aug 24, 2022 | 05:35 PM
BillK's Avatar
Interesting. This is from my Carquest commercial account. Shows 3 of the S261's in Winchester ?
Old May 19, 2025 | 10:26 AM
69 Olds Guy's Avatar
Any luck finding breaks, or did you use the 2 inch? I’m looking for 2.5 inch.
Old May 19, 2025 | 10:54 AM
mpolds's Avatar
The 11 “ x 2 1/2 “ Rear Brake Shoes for the 1965 - 1969 OLDS 98 — ALL —
ONLY —- has lonnnnng been Discontinued/ Obsolete by ALL companies / outfits….,
The GREAT NEWS is not only do I have them *** N.O.S. *** for you —- they are farrrrrrr superior than this current Chineseum garbage…..
I also have your Fronts —- which again , are farrrr superior to the Chineseum garbage which all those you are quoting can only provide…..
With that Chineseum garbage , you will rip up ( very expensive ) brake drums to smithereens in no time…..
Always best to simply call me —- 516 - 485 - 193five —- Craig…..
willypsilon
Aug 23, 2022 04:56 AM
Daniel Marsh
Brakes/Hydraulic Systems
Dec 16, 2013 04:26 PM
yeahbuddy
24
Dec 12, 2011 03:09 PM
phil7395
Aug 4, 2009 11:12 AM
luvmy58
Apr 12, 2008 07:26 PM
