Front disk brakes
Old May 5, 2020 | 02:32 AM
Allmyin's Avatar
Front disk brakes
I’m doing a front disk conversion with stock parts. I have a Assembly manual. Unfortunately I have page in my book is bad
. If someone has a better Picture would you please post it.
Old May 5, 2020 | 04:50 AM
You'll need to state what year vehicle and what page you need - it appears you need pg 105 but I wouldn't leave anything to chance.
Old May 5, 2020 | 06:57 AM
Allmyin's Avatar
You’re absolutely correct my apologies it’s for a 1970 cutlass S manual drum brakes all the way around. I am leaving at manual. I didn’t know if I needed to change the proportional valve and or the master cylinder Just double checking things I need to change and don’t need to change. I appreciate your response
Old May 5, 2020 | 07:11 AM
Unfortunately, my 1970 image from the Assembly Manual is no better than the image you posted.
Hopefully, someone will be able to provide a more clear image for you.
Old May 5, 2020 | 07:31 AM
therobski's Avatar
When I converted my 64 F-85 I asked a particular parts house to call me when they get a rebuilt pair of GM calipers. So I was lucky I guess and did not wait long at all, maybe 2 weeks. In my case I did a B-spindle upgrade and received special police car Caprice calipers. ( I had asked for them) Just for your thoughts...I much prefer rebuilt GM over Chinese-ism..
Old May 5, 2020 | 09:53 AM
cdrod's Avatar
Rodney
70 ASM page 105
I have attached the page you need.
Rodney
File Type: pdf
Old May 6, 2020 | 04:53 AM
70Olds442Guy's Avatar
70 olds 442 manual PDF you posted
Rodney
Hi Rodney I tried to download the PDF you sent yesterday in the post, but unfortunately I was unable to get it, help please!
Old May 6, 2020 | 12:27 PM
I copied & saved Rodney's .pdf then converted it to .jpg & rotated the orientation. HTH
Old May 7, 2020 | 05:44 AM
Talking Thank you Vintage Chief!
Old May 16, 2020 | 05:53 PM
Allmyin's Avatar
Thank you everyone for the help. Brakes are on and working. All new front lines are installed.
David DeCan
Brakes/Hydraulic Systems
Feb 19, 2016 09:41 AM
Wyze
Jan 9, 2011 12:19 PM
droptopcad
Oct 13, 2010 12:16 PM
501Paratrooper
May 29, 2010 08:38 AM
Southern_Hospitality
Mar 19, 2008 09:39 PM
