Front Drum Brake Question for 1965 442
Just starting to tear into this project, so I wanted to get the brakes dialed in. I removed the drum and hub as a unit. I see that most auto parts places sell the drums and have found some that sell the hub assembly. My questions is to remove the hub from the drum: Do you push out the lugs to unlock the hub from the drum or do you push the complete hub (from the center) to release it from the drum? Here a a few photos of the assembly. Thanks for the help.
Steve
Steve
Great! Thanks for the info. One drum looks like it can be turned the other was down to rivets. I will replace both drums as the hubs look good. Installation of the new drums is the same? Just push the lugs back into the new drum? Thanks.
yeahbuddy
Brakes/Hydraulic Systems
January 15th, 2014 02:10 PM
455Olds
December 8th, 2013 08:16 PM
501Paratrooper
June 20th, 2012 11:35 AM
