Caliper Questions
Old Apr 16, 2009 | 12:24 PM
oldsonharmont's Avatar
Caliper Questions
After replacing the front disc pads on my '71 Cutlass, I noticed the caliper pistons were slow and nearly stiff. I pulled them last night and found brake fluid that looked like old motor oil in the piston area. They still cleaned up pretty well, but I noticed some of the plating had deteriorated in the bores and some pitting was present. Are these salvageable, or should I pitch 'em and get new ones?
Old Apr 16, 2009 | 12:42 PM
kaz442's Avatar
Don't pitch them, use them as cores for new/rebuilt ones their cheap enough not to mess with the old ones. JKaz
Old Apr 16, 2009 | 08:25 PM
The beauty of the single piston calipers is that the seal slides on the piston. Pitting in the caliper bore really doesn't affect sealing of the piston. You can replace the seal (rebuild kits only cost a few dollars) and even replace the pistons if necessary - though the usually clean up with a little scotchbrite. And as noted above, even rebuilt calipers are not expensive.
Old Apr 17, 2009 | 02:14 AM
I ordered two rebuild kits today for $5 each and will reassemble everything tomorrow. Hopefully in time to still make it to the local taco stand for the weekly cruise in!
louie
Brakes/Hydraulic Systems
May 16, 2011 10:35 AM
oldzy
Dec 7, 2010 01:29 PM
oldzy
Oct 5, 2010 03:39 PM
Wilson05
Dec 3, 2009 08:49 AM
Z3d
Ninety-Eight
Nov 6, 2009 03:33 PM
