Prop. Valve to rear lines
Need advice ? Hooked up new disc brakes ,calipers , a lot of new suspension parts on my 1972 Cutlass . Im to where I need to plumb new lines but having an issue . The new proportional valve at the master cylinder cut out the distribution block on the frame . The rear 1/4 line have a 9/16-18 fitting and so does the prop. valve . I cant seem to find a coupler that size anywhere . How can I make this connection without running a new rear brake line ?
I heard rumors about a magic coupler for this problem but I never found one.
https://pitstopusa.com/c-320170-fitt...-fittings.html
https://www.oreillyauto.com/shop/per...gs---sae-18686
http://www.dormanproducts.com/c-176-...-adapters.aspx
If you must use the old line, can get the adapter to neck the 9/16 down to the standard 7/16 and then just connect a line from there.
