Prop. Valve to rear lines
Old Sep 13, 2017 | 06:53 PM
Cutlasskyle's Avatar
Need advice ? Hooked up new disc brakes ,calipers , a lot of new suspension parts on my 1972 Cutlass . Im to where I need to plumb new lines but having an issue . The new proportional valve at the master cylinder cut out the distribution block on the frame . The rear 1/4 line have a 9/16-18 fitting and so does the prop. valve . I cant seem to find a coupler that size anywhere . How can I make this connection without running a new rear brake line ?
Old Sep 14, 2017 | 07:11 AM
dalilama's Avatar
I had the same problem when I put my proportioning valve in to replace the distribution block. Could not find a coupler anywhere and I wound up running a new rear brake line. It was a *itch but it was the best solution I could come up with.
I heard rumors about a magic coupler for this problem but I never found one.
Old Sep 14, 2017 | 07:27 AM
NAPA stores have a whole assortment box of these. Unfortunately, most of the counter workers don't even know it's in the store.
https://pitstopusa.com/c-320170-fitt...-fittings.html
https://www.oreillyauto.com/shop/per...gs---sae-18686
http://www.dormanproducts.com/c-176-...-adapters.aspx
Old Sep 14, 2017 | 03:51 PM
This is what I need but the 9/16-18 coupler for 1/4 line doesn't exist . Its insanely confusing with all the brake upgrades that are sold to not have this simple piece .
Old Sep 14, 2017 | 04:07 PM
Because no one needs it. The 9/16 flare nuts on 1/4" line are a non-standard size used by GM to preclude incorrect connections of brake lines on the assembly line. That line only fits into one threaded hole, period. No one connects them like this, they just reflare the line to use a standard nut - or better, just run a line of the correct length.
If you must use the old line, can get the adapter to neck the 9/16 down to the standard 7/16 and then just connect a line from there.
NHolds
Apr 10, 2013 04:02 PM
nofiveo
Jul 28, 2011 02:08 PM
OLDSmobility
Brakes/Hydraulic Systems
Apr 29, 2011 08:15 AM
69Rman
Dec 11, 2010 08:48 PM
joe_padavano
Jul 1, 2009 10:10 AM
