Where can I get a 4 piston caliper?
Places like RockAuto sell (Cardone ?) replacements (well, they have them listed, but I've never seen one)...but I suspect these are the smaller bore versions...
I'm not sure which side you need (they are different obviously) but make sure whatever replacement you get has the proper line threads for your car. The driver side uses a standard 1/2"-20, but the pass. side has a funky 7/16"-24. Sometimes people cut the threads to something more common.
If you just need one rebuilt, there's several rebuilders like Lonestar Caliper & some brake machine shop in CA (can't remember the name), but turnaround time is usually a few weeks unless you just send yours as a core.
If you need a core, try FleaBay - I have seen some go by on there.... & CL
Hope this helps...
Decided to rebuild the original caliper. Has anyone had this done? Can you recommend a shop?
We contacted a distributor in Canada about a rebuild kit and a week later we call to check on delivery. They never sent it! Turns out it's on backorder
But they never called us!
Thanks again!
Thanks again!
To properly fix the four piston calipers, you need the stainless sleeves installed in the caliper. White Post Restorations here in VA is one of the premier vendors who sleeve these calipers.
My issues:
1. I sent my old ones in as cores for a set of freshly rebuilt ones. I now wish I'd paid the extra few bucks to have them 'babysit' my originals instead of exchanging them. The ones I got back were made out of mismatched halves....but that's prolly common in the rebuild world.
2. Every single threaded hole (mtg & fitting) was a crusty mess. I had to chase them all with taps....and that weird 7/16-24 required me to order, & wait for, a tap.
3. They're painted with some thick cast color stuff. They look OK, but this paint or whatever looks like its a 1/8" thick.
Haven't used them yet as the car is still in pieces. I hope they work OK....
I have heard good things about Karps ( http://www.resleeve.com/ ) & they were nice on the phone, but have not used them.
Bernhard
Jan 13, 2013 05:06 PM
