Wheel bearing squeak?
Old Oct 4, 2018 | 11:30 AM
mitchy's Avatar
So with my new disc brakes the wheel bearing on the passenger side seems to be squeaking I think. I pulled the rotor removed the inner seal and found some browning on bearing where it sits on the spindle but no blue discoloration on the rollers or anywhere and also there was some browning on the spindle where the inner bearing would sit. I replaced the inner bearing with a timken bearing and seal but for some reason its still squeaking and im not sure why. Ive attached a video so you can hear it for yourself. Note the outer bearing was fine and i saw no discoloration on that one. Any input would be helpful thanks!
Old Oct 4, 2018 | 11:47 AM
classicmuscle442's Avatar
Would put bearing on spindle by itself dry and check for fit. Think you might find it is too loose on spindle. Should have no slop when you rock the bearing on spindle.
Old Oct 4, 2018 | 11:55 AM
mitchy's Avatar
Unhappy
I did test fit the new bearing on the spindle it went on with zero play while on the spindle.
Old Oct 4, 2018 | 11:57 AM
Would check again, sure looks like the bearing is getting hot. Are the bearings new and name brand?
Old Oct 4, 2018 | 12:28 PM
Can'y hear a noise through my laptop. First the grease gets packed only in the bearing, not inside the housing. You just put a light coating on the spindle. Did you also replace the race? Did you set your preload correctly?
Old Oct 4, 2018 | 12:43 PM
mitchy's Avatar
I bought the lisle bearing packer and repaced the new bearing and the race wasnt scored and was smooth with no discoloration i greased the spindle and the race well before reinstalling
Old Oct 4, 2018 | 01:13 PM
The bearing is spinning on spindle, it shouldn't. Not clear on your post, new bearing but didn't change race?
Old Oct 4, 2018 | 01:31 PM
Common practice to change the race and the bearing. The old race will be matched to the wear on the old bearing. Are you sure its a wheel bearing and not brakes.
Old Oct 4, 2018 | 01:50 PM
mitchy's Avatar
Im not sure if its the bearing or the pads or maybe the caliper is sticking but these rotors calipers and pads
havent even seen 500 miles yet which is why the i wouldnt suspect the race the race is very clean and new and their already squeaking ive been told the metallic in the pads can contribute to this noise but the signs of excessive heat on the spindle lead me to believe otherwise. Could it possibly be a bad caliper that isnt opening up as far as it should when i let off the brake leading to over heating issues?
Old Oct 4, 2018 | 03:34 PM
Does the squeal go away when you apply the brakes? Does the steering pull to one side )except drifting because of the crown of the road) when you apply the brakes or while driving?
Old Oct 4, 2018 | 03:53 PM
mitchy's Avatar
No i don't notice a pulling and the squeak only happens when the brakes are lightly applied then stops when the pedal is pushed foward more. But it occasionally happens when im cornering and all the weight is on the passenger side but thats only happend a couple times. Also it usually only squeaks when im going 30 or under
Old Oct 4, 2018 | 03:58 PM
That's brake pad noise and is probably going to happen until the pads wear a bit. If its happening while turning it means your wheel bearings are not adjusted right allowing play and the rotor to tilt. How are you adjusting the wheel bearings?
Old Oct 4, 2018 | 05:42 PM
ragz442's Avatar
Like mentioned previously, you have to replace the race with bearing, that is why they come together as a matched set. I would get another bearing, drive old race out with a punch and install new race with a brass drift or a race installer if you have one.
Old Oct 4, 2018 | 06:08 PM
mitchy's Avatar
Well ill give the race a try and ill get back to you guys. I appreciate the input.
Old Oct 5, 2018 | 10:11 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
When is the last time the caliper soft brake line was replaced? They should be replaced every so often as they break down internally and can act as a one way valve not allowing fluid to back-flow when releasing the brake pedal. Replace all 3 if you have never done them.
Another thing to try is to knock off the sharp edges of the brake pads. I use a die grinder with a sanding disc but any method will work. Take about a sixteenth to an eighth inch off at a 45* angle. By easing the sharp edge on the pad it eliminates the pad chatter as you hear as squeal.
Why did you need a bearing puller? You shouldn't. Are you installing the race properly with a race/seal tool? The race will go in a lot easier if you stick the race in the freezer and apply a little heat to the hub, 150*F max so sparingly.... Snap a picture of the spindle.
I always put a scoop of grease between the seal and the inner and in the center of the hub along with hand packing the bearing. Too much grease will wick out. Its just a hub with 2 bearings why not apply extra grease. Been doing it for 45 years on countless vehicles without any adverse effects.
Yes always replace bearing and races as sets. You should do the outer as well. Do both axles.You are in there why not do it right....with USA made bearings seals and grease!
Source everything through BDI Inc. They will ship USA made parts to your door. ASK FOR USA MADE cuz they will quote the chineasium junk first. Less than 15 dollar difference between the two, (for both axles seals and all).
mother$hip89
Feb 16, 2019 12:29 PM
mother$hip89
Sep 28, 2018 01:22 PM
Supernaut72
Aug 3, 2016 08:14 PM
oldzy
Brakes/Hydraulic Systems
Dec 16, 2010 06:41 AM
Captain_Fish
Drivetrain/Differentials
Oct 3, 2010 12:10 PM
