Want to convert to rear discs, but what is the axle pattern?
Hello, im woundering what bolt pattern i have for the brake install, does any know what my 10bolt 8,5" non c-clip axle have? i think i have that one with red circle around...
and i found this kit on ebay, but it says its for A-body cars, but for non- clip axle,, so could it fit my axle too? did the a-body axle have same drum setup like an b-body axle with 9" drums and 5x4,75" pattern?
http://www.ebay.com/itm/Rear-Disc-Br...45538a&vxp=mtr
Or maybe this? for f and x bodys
http://www.ebay.com/itm/Staggered-GM...3994f2&vxp=mtr
thanks
thanks
Hi again, can someone help me with this, What is the thickness of the backing plate? And what is the distance from the outside of the backing plate to the outside of the axle flange, when the axle is pushed all the way?
look at the pic below, the blue one is what i need to know, the other pic is my axle, somebody knows the dim on the axle with the bolt pattern?
Its hard for me to find out right now cause i cant dissaseble the brakedrume and check it self :/
really, does it fit? is it for 15" rims and up? and have u a Non c-clip axle 10 bolt 8,5" that the 85 camaro kit fits on? and bearingsize out dim 65mm? the seller need to know the axle flange distance if so in my opinion.. and the disk dim for the bolt pattern.
or do u have a link for ur kit? any tip would help ,im not sure what axles the camaro 85 has
txrob779
Drivetrain/Differentials
15
February 26th, 2014 11:08 AM
lshlsh2
February 3rd, 2013 08:40 AM
Aceshigh
Brakes/Hydraulic Systems
June 24th, 2010 09:05 AM
