Swooshing sound when pressing down brake pedal
Old Oct 28, 2012 | 12:16 AM
steel's Avatar
http://a4.l3-images.myspa
I have front disc & rear drum brakes on my 85 olds delta 88 & when i press on the pedal i hear a swooshing sound. The fluid level seems ok & no leaks. The pedal doesnt go all the way to the floor & the brake light does not come on. When the car is off i also hear a swooshing sound when i press on the pedal. The brakes do seem to work fine. Whats going on ?
Old Oct 28, 2012 | 05:10 AM
1970cs's Avatar
Lansing built
First question, is this something new that has just developed?
For the most part in most vehicles with stereo turned off you will hear a swoosh or similar sound when you depress the brake pedal!
Pat
Old Oct 28, 2012 | 05:53 AM
+1.
Do you hear the sound the whole time that you hold the pedal down, or only while you are moving it toward the floor?
Old Oct 28, 2012 | 11:37 AM
steel's Avatar
Originally Posted by MDchanic
+1.
Only when i move it towards the floor. I noticed the sound with the stereo off last friday.
Old Oct 28, 2012 | 11:46 AM
henryk8398's Avatar
Hangin' out...
+1.
+2 Sounds normal to me.
Old Oct 28, 2012 | 12:44 PM
jaunty75's Avatar
Turn the stereo back on!
Old Oct 28, 2012 | 01:26 PM
That's the normal sound of the booster working.
Old Oct 28, 2012 | 02:12 PM
aliensatemybuick's Avatar
"me somebody" site member
Perhaps your booster has a pinhole leak, or is leaking from behind (where the brake pedal linkage goes trough, there is usually a plastic or nylon shield that goes through the firewall). The fact that the brakes still seem to work with proper boost may mean it is insufficient to prevent the booster from accumulating vaccuum while the engine is running.
Old Oct 28, 2012 | 02:46 PM
Funkwagon455's Avatar
Is the pedal travel more than you have noticed before? My wife had complained that occasionally the brake pedal on her '86 Wagoneer would go to the floor with no brakes until pumped. When I drove the vehicle I could not duplicate the problem. After the vehicle sat for two months I went to drive it just to keep it moving and noticed that though the brakes did work, a woosh and excessive pedal travel was clearly evident. A new master cylinder and brake bleed improved the braking greatly. If you feel excessive travel, or suspect a problem I think that an o/h master cylinder is cheap insurance to avoid a potentially catastrophic scenario. A loss of brakes in traffic at 70 mph will get your attention (and pedestrians) very fast. I'm not insisting that anything is wrong,.....just follow your mechanical instincts and continue to enjoy your Olds..
Old Oct 28, 2012 | 03:44 PM
steel's Avatar
What if the fluid level is not full & low just a little bit ? The braking power seems good. The noise sounds like its under the dash near the pedal.
Old Nov 6, 2012 | 05:28 PM
steel's Avatar
My cousin whos been a mechanic for over 30 yrs checked out my car last week. He said that "swooshing" sound is normal the booster & master cylinder is good (No loss of brake fluid). The brake pads & shoes are good as well. I myself feel the brake lines need to be bled but my cousin said they dont.
Old Nov 6, 2012 | 05:33 PM
Well, there ya go. It's nice to be reassured.
(And if you really want to bleed the brakes, you always can... )
Old Nov 7, 2012 | 07:13 AM
White Spyder's Avatar
After having to replace my proportioning valve due to a clog I have found out from brake and fluid/oil experts that you should flush out your system with new fluid every 5-7 years. Most systems will develop moisture (water) over time. That is not good for the system and can cause internal rusting of the lines. On top of that dirty fluids does not preform as good.
I am changing the fluid on all 4 of my classics this weekend.
Old Nov 7, 2012 | 08:50 AM
69HO43's Avatar
If the brakes are fine otherwise, I vote for a deteriorated silencer. On the back of the booster under the rubber "boot" where the actuating rod goes through, there's a silencer to muffle the "whooshing" sound it makes when the brakes are applied. Usually made of felt or breathable foam.
Old Nov 7, 2012 | 10:06 AM
I did not know that.
Old Nov 7, 2012 | 11:48 PM
steel's Avatar
My cousin says unless the swooshing sound bugs me i could leave it be. Leaving it alone will not hurt anything or cause damage. What does dirty brake fluid look like ?
Old Nov 8, 2012 | 03:52 AM
Correct.
Not clear.
Old Nov 8, 2012 | 04:51 AM
garys 68's Avatar
Learn something new every day. I always thought they were just there to keep dust and dirrt out.
oldspackrat
Mar 30, 2013 04:57 AM
oldspackrat
Aug 23, 2011 08:14 PM
Coltonis
Jan 29, 2010 03:40 PM
Dapapadon
Jan 21, 2008 10:27 PM
