Stuck proportioning valve
Old Feb 2, 2008 | 04:41 PM
Chumley's Avatar
When I bled my brakes, the proportioning valve button that is supposed to be depressed while bleeding was stuck in that position. Is there a way to make it pop out again? ( preferably while still mounted and the brake lines connected to it)
Chumley
Old Feb 28, 2008 | 06:28 PM
Chumley's Avatar
Thought I would refresh this post since some who might be able to help might have missed it.(Joe?) Thanks Chumley
Old Feb 29, 2008 | 06:41 AM
The button hardly moves. If you are able to bleed the brakes and they work correctly, you don't have a problem.
Old Mar 1, 2008 | 05:24 PM
Chumley's Avatar
Thanks Joe, I just thought that the button should depress enough that you would notice it, as the GM repair manual refers to a special GM tool (J- something or other) that you use to hold the button in while bleeding. I started the engine today and the pedal feels "normal" as far as I can tell. The real test is on the road. Just how much is "hardly at all"? Thanks....Chumley
oldspackrat
Oct 29, 2017 07:38 PM
Mike H.
Brakes/Hydraulic Systems
Mar 7, 2013 10:48 AM
oldzy
Feb 16, 2011 07:52 AM
Chumley
Feb 2, 2008 04:35 PM
W30post
Nov 25, 2007 10:18 AM
