Stiff pedal opinions
Old Jun 24, 2018 | 01:40 PM
Rjharp's Avatar
Hi guys. Just bought my 58 Super 88. It pretty much has no brakes. Pedal is very hard wether the car is running or not. The guy I bought it from says it’s the wheel cylinders but my thought is it must be the booster is bad. I would love to hear the opinions on his.
Old Jun 24, 2018 | 03:32 PM
Charlie Jones's Avatar
Phantom Phixer
Could be either or both .
The important thing is , if the brake system hasn't been properly serviced recently .
Then all four drums should be removed , the wheel cylinders re-built or replaced .
Brake shoes should be replaced if worn more than 50 percent . The drums must be machined or replaced if new shoes are installed . Brake hoses should be replaced if they look old .
The brake booster is a Bendix Tredle-Vac unit . The master cylinder is part of the booster unit , and the unit must be re-built .
Old Jun 25, 2018 | 07:37 PM
76olds's Avatar
Hookers under Hood
I agree with Charlie.
Take all 4 drums off and inspect. Could be a broken spring hung up in between the shoe and drum, wheel cylinder pin/s not retracting completely, or the brake booster.
Eric
jpatfarrell
Brakes/Hydraulic Systems
Dec 6, 2018 01:09 PM
car_designer
Aug 11, 2016 10:21 PM
justinj
Nov 29, 2015 06:07 AM
Rocketowner
Apr 9, 2014 08:36 PM
