Stiff Brake Pedal, very little brakes
I have replaced my master cylinder and brake booster with http://rover.ebay.com/rover/1/711-53...m/200619751357 and a Centric master cylinder
CENTRIC 13062024 (130.62024). I have good vacuum to the booster and bench bled the master cylinder and all the wheels were bled as well. I checked for Misalignment of the brake rod and it appears to enter the master cylinder correctly. Any ideas on what I've done wrong?
Thanks,
Randy
Thanks,
Randy
Check the bore size of the new Centric master cylinder against the cylinder that was in the car .
Centric has a penchant for being wrong with their applications at times .
A master cylinder bore that is larger than it should be , will cause a hard pedal .
Thanks Tom, the rod is connected to the correct hole so that's not it. I will try to trouble shoot the booster today. Between the two new parts, I'm not sure what it is.
Well my new Inline Tube brake booster is a bust. I purchased it in March so wish me luck on the return. We'll see what kind of customer service they provide first hand. I am attaching pictures of my newly installed engine and my homemade cadmium plate job I did on my old booster. (Just red,green and gold paint lying around and a clear coat). It will have to do. At least it works. Such a pain to remove and install though. I somewhat anticipated this so I previously put a large diameter nut on the lower left hand booster stud so take up much of the thread length making it easier to install and remove the nut from hell.
Thanks again for all the help!
Randy
Randy
Endurance
July 14th, 2015 04:01 PM
agtw31
Suspension & Handling
15
June 14th, 2010 06:01 AM
