Starfire Brakes
Starfire Brakes
I have a 1965 Oldsmobile starfire and using it as a daily driver. Due to safety, I want to update the vehicle to a dual circuit brake system and disc brakes in the front. From the research I have done the firestar is a B body I have not been able to find a bolt-on disc brake system for this car.
Questions I am throwing out to the forum:
1. Has anyone on the forum updated their 1965 firestar to front disc brakes? How did you do it?
2. Would a conversion kit for a '65/'66 Delta 88 or Chevy Impala and then put a kit made for those cars on this firestar? I seems logical to me, but I have not compared the parts side by side to make sure the geometry is the same between the Chevy and Olds. I'm sure the Delta parts would go on without a problem. But not sure enough to spend the money
Any information is appreciated. Thanks!...Dan
I believe the B body cars did not offer disc brakes until 1968 or 69. Then in order to convert or use that disc brake set up (keeping the original 5x5 lug pattern verses the after market Impala conversion that changes the lug pattern to 5x4.75), you need the spindles, master cylinder, booster, proportion valve, along with the discs and calipers. Plus you'll need to up your rim size to 15 inch. Then FYI, replacement parts for the OEM '69 set up is very hard if not impossible to find. Just enjoy your 4 wheel drums
![](https://classicoldsmobile.com/forums/images/smilies/smile.gif)
Yes, your Starfire is a B-body, same as an Olds Delta 88. Despite this, the chassis and suspension are completely different from Impala parts for the same year. Nothing interchanges. The best solution is to use the disc brake spindles and parts from a 1969-70 Olds full size. The spindles are bolt-on. I've got this setup for my 67 Delta (the 65-70 cars use the same front suspension and spindles interchange).
Yes, Scarebird makes an aftermarket kit using rotors that are smaller than the factory ones. I've previously posted my concerns about that and similar aftermarket disc brake conversion kits. Your money, your car.
I believe the B body cars did not offer disc brakes until 1968 or 69. Then in order to convert or use that disc brake set up (keeping the original 5x5 lug pattern verses the after market Impala conversion that changes the lug pattern to 5x4.75), you need the spindles, master cylinder, booster, proportion valve, along with the discs and calipers. Plus you'll need to up your rim size to 15 inch. Then FYI, replacement parts for the OEM '69 set up is very hard if not impossible to find. Just enjoy your 4 wheel drums ![](https://classicoldsmobile.com/forums/images/smilies/smile.gif)
Scarebird sells aftermarket brackets and a parts list of stuff you get from an auto parts store. As I said, be informed about how these aftermarket designs are less capable than factory disc brakes (smaller, narrower rotor, etc). You find them on the Scarebird website.
Mocephus
October 1st, 2021 09:45 AM
65Delta88J-Scril
Brakes/Hydraulic Systems
April 9th, 2011 10:10 AM
