Slapping Noise when brakes applied
Old Oct 30, 2009 | 10:41 AM
dallasite21's Avatar
I have a 1971 Cutlass, and I am having a problem when I hit my brakes. This only occurs when I am going faster than say 40mph and I hit the brakes hard. I feel a knocking that vibrates up through the shifter and I hear the knocking noise like somoeone is knocking on your door really fast and the tempo slows as the car slows. I almost feel like it would be my emergency brake pulling tight for what ever reason, but I dont know... Anyone else ever have this problem?
Old Oct 30, 2009 | 12:08 PM
This could be a lot of things. Certainly a warped rotor could cause this problem. I'm leaning towards worn steering or suspension parts, however. Have all the moving parts in the front suspension checked for wear.
Old Oct 30, 2009 | 12:09 PM
Bluevista's Avatar
Registered
It sounds like it could also be the rear end/differential or universal joints if it's knocking that fast then slows. I would check the U-joints soon, don't want the driveshaft falling off and doing major damage.
Old Oct 30, 2009 | 01:54 PM
gearheads78's Avatar
car guy
Busted transmission mount letting the driveshaft hitting the floor?
Old Oct 30, 2009 | 04:29 PM
I think the transmission mount sounds like the most logical thing... You are about the third person I have had tell ne that. The next question is how difficult is it to replace?
Old Oct 30, 2009 | 06:23 PM
car guy
Real easy. Should be 3 or 4 bolts. Get the car up on stands or ramps, loosen the bolts, jack up the back of the trans a little to pull the old mount and install the new one. If you don't have tools or equipment and are in Dallas (assuming from user name) I can knock it out for a few bucks. PM me if you need to.
72allblackcoupe
Apr 6, 2014 07:20 PM
69goatpgh
Feb 24, 2013 09:22 AM
1carsick
Brakes/Hydraulic Systems
23
Oct 2, 2012 05:50 PM
russell-t
Apr 30, 2011 05:56 AM
sully
Mar 30, 2007 11:26 AM
