Replacing metal brake lines and proportioning valve?
Old Jan 3, 2013 | 07:40 PM
zodiacblueS's Avatar
I had a metal brake line fail this fall and will be replacing all the lines (metal and rubber) along with the prop valve with new pieces from inline tube. It's a '73 S with factory discs on the front and drums in the rear. The front calipers are new/rebuilt installed last year.
Questions:
1) Will I need to remove and bench bleed my new/rebuilt master cylinder like I did when I installed it last year?
2) What about the proportioning valve? Does it bleed itself with the rest of the system or is there a separate procedure to get it "pumped up"?
Thanks in advance.
Old Jan 4, 2013 | 08:13 AM
Probably not, but it depends on whether or not all the fluid leaks out of it when you disconnect the lines.
Combo valve will self-bleed with the rest of the system. If you are bleeding with a two-person, pump-the-brakes approach, just be careful not to press too hard on the pedal and force the differential pressure switch hard to one side, where it can get stuck. Use gentle force on the pedal until there is fluid in both circuits of the brakes.
Old Jan 4, 2013 | 09:45 AM
Thanks Joe
Being 62 myself, I can really appreciate and Old(s) fart. Thank you sir.
oldspackrat
Oct 29, 2017 07:38 PM
Mike H.
Brakes/Hydraulic Systems
Mar 7, 2013 10:48 AM
GStage1
Apr 11, 2012 11:39 AM
Curts1970cutlass
Apr 9, 2012 03:39 PM
Chumley
Feb 2, 2008 04:35 PM
