Rear Brakes
Rear Brakes
'69 Olds Cutlass conv. 350 Rocket. Last time I worked on this was about 12 yrs ago. I needed new rear drums but every where i went I got drums that left about 1/2" of shoe not covered by the drum, ie center of hub is dished deeper than the basic hub. Dont know if this is standard for 69 or if previous owner put a bastard diff. on it. Any Suggestions???
The Vista rear end has different shock mounts, I don't know if the Cutlass wagon used the Cutlass or Vista shock mounts. I believe that's the only difference between the Vista and Cutlass/442 rear ends. Can you post pictures of the brake assembly and new drum that doesn't fit? John
If he was given front shoes for the rear, then the retainer pins would be too short....I put Vista backing plates, shoes and cylinders on the rear of my convert w/ correct diff to see if it would stop better...it's not on the road yet
still in the paint shop..
Yellowstatue, at the risk of being called a thread highjacker let me say I've purchased a couple sets of 11"X2" brake assemblies from 1976-77 Cutlass's. I've been told that they can be swapped over just like the Vista brakes to try and get more braking capabilities. BUT... those brake parts are on a shelf waiting for me to actually put them on something
