Proportioning valve options?
Old Jul 10, 2014 | 11:54 AM
zodiacblueS's Avatar
Does anyone know if I can use a different proportioning valve for my 73S (front discs, rear drums) other than the one from Inline Tube? Last new unit now leaks at the front rubber cover, and I would love another source. Maybe another year or even make? Thanks in advance.
Old Jul 10, 2014 | 12:25 PM
midrange's Avatar
Shaking out the cobwebs..
I had the same problem, along with some of the fittings constantly leaking. I went with a Wilwood adjustable prop valve from Summit for the rear and ran the fronts straight from the MC.
Obviously it won't be correct from a factory/purist standpoint, but then my car is far from factory anyways.
Old Jul 10, 2014 | 03:41 PM
I think just about all GM front disc-rear drum cars from '71 through the '80s used the same proportioning valve, so you should be able to find one fairly easily at a salvage yard. I am sure someone with specific details will post up.
oldspackrat
Oct 29, 2017 07:38 PM
Mike H.
Brakes/Hydraulic Systems
Mar 7, 2013 10:48 AM
Jul 5, 2012 09:34 AM
Chumley
Mar 1, 2008 05:24 PM
W30post
Nov 25, 2007 10:18 AM
