Proportioning Valve leak please help!
Old Sep 16, 2015 | 01:05 PM
W-27's Avatar
I have a 68 442 which i converted to front disc brakes (1971 model with single pistons) and i am on my second proportioning valve in 2 weeks due to the fact that it leaks from the metering valve. Its made by MBM model PV2. I used silicone brake fluid as i put new stainless steel lines as well. I can i stop it from leaking? Do i need to remove the metering valve and sealed it with white tape used for brake lines? Is it due to different viscosity? Please help.
Old Sep 16, 2015 | 08:28 PM
The combo valve uses inverted flare fittings, which seal on the flare. Tape on the threads is useless; the threads DO NOT seal. If two new valves leak, the problem is probably not the valve but the flare on the line going into it.
Old Sep 17, 2015 | 06:51 AM
W-27's Avatar
Old Sep 17, 2015 | 06:53 AM
W-27's Avatar
Joe, what would you suggest i do to alliviate the issue? The leak is defenetely coming from the metering valve.
Old Sep 17, 2015 | 08:18 AM
Tom442's Avatar
Did you flare your own lines?
I understand you put new Stainless steel lines on this valve. I have done some double flares on regular tubing before, they looked perfect. BUT there was a tiny line on the face of the flare where the tubing was seamed that caused a leak. You might want to really closely examine those flares.
Just a thought.
Old Sep 17, 2015 | 10:10 AM
70cutty's Avatar
Beer Connoisseur
If you are using stainless line, it has to be really really tight. I had the same problem when I switched my lines to stainless, it leaked at almost every connection. I had to tighten all of them as much as I could.
Old Sep 17, 2015 | 12:01 PM
W-27's Avatar
Just a thought.
Tom, what did you do to fix the situation?
Old Sep 17, 2015 | 12:02 PM
W-27's Avatar
I did that, they are as tight as i could make them any more and they would strip the threads.
Old Sep 17, 2015 | 01:34 PM
Tom442's Avatar
"Tom, what did you do to fix the situation?"
I had to re-bend the lines (lucky it was the front left) and they held the second time around...
oldspackrat
Oct 29, 2017 07:38 PM
Mike H.
Brakes/Hydraulic Systems
Mar 7, 2013 10:48 AM
Chumley
Mar 1, 2008 05:24 PM
Chumley
Feb 2, 2008 04:35 PM
W30post
Nov 25, 2007 10:18 AM
