Plase Help
Old Sep 8, 2008 | 06:05 PM
Satellitecentral's Avatar
Plase Help
I have been working on my newly aquired 66 Dynamic 88 , and have got to the stage off sorting out the er, no exsisent brakes, well , they do work , but boy are they hard to work,
Neighbour diagnosed a bad brake booster.
Next issue i spent this afternoon , running to Napa,Autozone,Oriellys, an Advanced , all off them have the part number , but not one seems to be able to order it, it,s on theie Computer , but when you say Yes I,ll take one it,s always the same , no stock , an no way off ordering it ?
any Ideas, confused
Old Sep 8, 2008 | 07:21 PM
rocketraider's Avatar
Oldsdruid
You'll have to bite the bullet and send yours off for repair, unless you find a junkyard piece that will likely be no better than what you have.
Google "brake booster rebuild" and you'll get several places that do it. It's gonna cost a couple hundred IIRC.
Old Sep 8, 2008 | 07:56 PM
Oh well
I thought for sure I could have found a re manufactured unit someplace,
I hate sending stuff off, after all if it,s lost i,ll be well screwed.
Maybe have to start calling junk yards,
What other if any, Olds used the same booster as my 66 Dynamic 88 4 door
Or has anyone retrofitted a different , more modern unit?
Old Sep 9, 2008 | 06:18 AM
Oldsguy's Avatar
Past Administrator
Did you check with Kanter Olds?
Old Sep 9, 2008 | 06:40 AM
Rallye469's Avatar
If Kanter can't help, you can always put an aftermarket booster
on it. I can't speak from experience for '66, but most GM's
shared the same bolt pattern on the firewall.
I don't think it would be too hard to retrofit the booster.
here's one
http://www.jegs.com/i/JEGS/555/631012/10002/-1
Old Sep 9, 2008 | 07:49 AM
Bluevista's Avatar
Registered
I checked Rock Auto real quick and they have 2 different ones for a Dynamic with/AT and other 1966 models with return and rebuild, and to contact customer service for details. Call them and see if it is available, worth a shot anyway. I use Rock Auto and have never had a problem, good service and parts.
Allan
http://www.rockauto.com/
Old Sep 9, 2008 | 07:09 PM
dynamic88's Avatar
satellite, i just finished a 3 year restro on my 65 dynamic 88 convertable. im pretty familiar with just about everything on these cars. my power booster was sent out to be rebuilt, but you can buy after market ones cheaper. just look around on the internet. if you need help with questions on yours let me know and good luck. chris
Old Sep 9, 2008 | 08:18 PM
Thanks for the reply Chris
I sent you a Private Message , with details , an my email addy
Your Car is KILLER
Love the rims
Old Sep 10, 2008 | 06:51 AM
dynamic88's Avatar
thanks paul i sent you a email with info
Old Sep 10, 2008 | 06:59 AM
dynamic88's Avatar
paul car looks like its pretty solid. be a good one to fix up. mine was a lot worse when i first brought it home. it sat out in a barn for 20 plus years uncovered collecting bird ****.
if you need anything let me know. chris
Old Sep 16, 2008 | 10:46 AM
Kaline's Avatar
I ran into the same issue on my '64 Dynamic 88 convertible. I sent mine out to Power Brake Booster Exchange. They turned the booster around in 4 days for me. It works great, and looks pretty good with the fresh semi-gloss black paint they applied.
http://boosterdeweyexchange.com/
Best of luck.
nolabigdawg
Nov 16, 2014 06:45 PM
MJAKS462
Apr 15, 2010 02:34 PM
silverriff
Mar 24, 2010 06:36 PM
martine
Jan 22, 2009 01:13 PM
ToronadoGuyDenver
Brakes/Hydraulic Systems
Mar 18, 2007 02:52 AM
