New Master Cylinder lost brake pressure
Old Nov 27, 2011 | 03:42 PM
jcddyy's Avatar
Unhappy New Master Cylinder lost brake pressure
Happy Holidays Olds fans. About a month ago I noticed a small leak bw the MC and power booster. I began to lose pressure but as I pumped brakes the pressure began to build back up. I have the service manual and from trouble shooting I first manually bled the brakes which helped some but the leak between the booster and MC was worse. Today I installed the MC as the service manual stated. I have bled the brakes over and over again. I still have no brake pressure. Can somebody help me please. I have scrolled thru many threads and it looks like im missing something. Is bench bleeding the process of bleding the MC before install? I didnt do this. I own a 72 cutlass with drums all the way around. Maybe soon I can upgrade to a Disc conversion. Hope santa is an ClassicOlds member.
Old Nov 27, 2011 | 04:24 PM
jcddyy's Avatar
Originally Posted by Prostreet Lamborghini
You needed to bench bleed the master cylinder with a little plastic bleeder tube kit. To get all the air out of it before you bolt it on the car. then keep it full of brake fluid when you bleed the wheels. If there is air in it anywhere no brakes !
I will in the morning. Is it as simple as attaching plastic tubes with plugs and impacting the piston part that contacts the booster? any tips?
thanks for reply
Old Nov 27, 2011 | 04:27 PM
You've answered your own question.
The M/C must be level when bench bleeding, which is why you can't do it on the car, where it is mounted at an angle.
Old Nov 27, 2011 | 04:31 PM
There are instructions with the new M/C.
Install the plugs they gave you and follow their instructions.
Basically, you clamp the M/C in a vise and push the piston in all the way, over and over, until the bubbles stop.
If you don't have a steady vise available, you can press the piston with a hammer handle while holding the M/C against a tree or a sturdy wall.
Old Nov 27, 2011 | 04:35 PM
jcddyy's Avatar
I just wasnt entirely sure. I do appreciate the help. Thanks
Old Nov 27, 2011 | 04:38 PM
jcddyy's Avatar
Cool . Now I just need to find the box! Will the piston push out on its own once it is pushed in?
I dont have a vise but I do have walls and trees. Thanks again. Im a better learner when Im hands on honestly.
Old Nov 27, 2011 | 04:44 PM
Put the master cyl in a bench vice...
He doesn't have a vise.
Oh yeah. It's got a STRONG spring, which is why you need a vise or a tree.
Without a vise, you'll have to prop the M/C against a sturdy object, hold the hammer handle or whatever you use with both hands, and lean your body into the M/C to depress the piston, because you want to keep the force line straight into the M/C, and not off at an angle. That's why a vise is easier.
Old Nov 27, 2011 | 04:57 PM
jcddyy's Avatar
I got it. Now was there any harm done installing the master without bench bleeding?
Old Nov 27, 2011 | 04:59 PM
jcddyy's Avatar
Put the master cyl in a bench vice, use some kind of rod, screwdriver, ect. fill the master cyl. with brake fluid. with the open ends of the tube curved to return the fluid back into the top of the master cyl. slowly push the rod in and out watching for air bubbles coming out of the bottom small holes in the filled master cyl. do it slowly till the bubbles stop. should be instuctions with tube kit. Dont get the brake fluid in your eyes or on your car paint it can strip your paint.
Thanks . Safety first always. I did get brake fliud on the last paint job and learned the hard way.
Old Nov 28, 2011 | 06:10 AM
Lady72nRob71's Avatar
Yep, it must be bench bled. I doubt you did any harm to the MC. Just remove it again and bench bleed it.
See how I did it without a vice here:
https://classicoldsmobile.com/forums...tml#post331973
I also had some helpful tips in there, too.
Do not fill more than 3/4 full to avoid spillage when installing it on the car.
Old Nov 28, 2011 | 06:29 AM
lshlsh2's Avatar
71 cutlass convertible
I used part of a 7/8 inch wood dowel to bench bleed mine.
Larry
Old Nov 28, 2011 | 01:04 PM
jcddyy's Avatar
I see. I used your idea an set up a board to bench bleed the MC. I found the plastic tubes and followed the directions and also read your thread . I did exactly as instructed. I must have pushed the piston in a few hundred times over an hour and a half time frame. I installed the MC just as you did in the thread and used the "two man" bleed method. I went around the rotation three times and still no brake pressure. The fluid coming out of the wheel cylinders are clean and the flow is responsive to the petal. I inspected the brake lines and looked for leaks again. I didnt find any leaks. I finially just took the MC off and returned it to bloody Autozone. It was a reman and went to a local guy down the street who had a new Dorman for 35$. Im still stuck and can hope it was just the POS i bought at AutoCrap.
Old Nov 28, 2011 | 04:50 PM
Did you redo the rest of the brakes or have the shoes off? If so, you MUST adjust the shoes to be close to the drums. If they are not, then you will use up all your pedal travel moving the shoes...
Only other issue would be a bad master if you bled it right (sounds lke you did)...
Old Dec 1, 2011 | 06:41 PM
jcddyy's Avatar
Only other issue would be Oooooo a bad master if you bled it right (sounds lke you did)...
No I didnt. I put new shoes and cylinders a month ago.
I bench bled the new MC(not a reman) and installed. Bled the system again and still no pressure. I called a couple of shops and spoke with mechanics there. When im bleeding the brakes the car is off and I get real good pressure while im bleeding. When I turn the car on brake petal hits the floor. The mechanic said its my booster. I went and bought a new one installed .
Do I have to bench bleed th MC again or can I just bolt on the MC and bleed the system?
Old Dec 1, 2011 | 07:18 PM
If the M/C has not been run dry, you do not have to bench bleed it again.
Old Dec 1, 2011 | 07:40 PM
With as long as it can take to get a booster off, it might run dry just by seepage around the port plugs...
Old Dec 1, 2011 | 08:24 PM
jcddyy's Avatar
I better bleed it again thanks for the help. Hopefully it doesnt rain here in Dallas tomorrow
Old Dec 1, 2011 | 08:25 PM
jcddyy's Avatar
I guess I can check for bubbles before I slap it back on.. Thanks Eric
Old Dec 2, 2011 | 05:16 AM
Yea, just put the bench bleeder kit back on it as best you can and hopefully it will not leak more. Do another quick bench bleed before reassy.
You can have your brake booster rebuilt if you want to stay original and can let the car be idle a few weeks. Not too much more than a "might fit" chinesium replacement.
Supposed to rain Sat and Sun, at least so they say...
Old Dec 10, 2011 | 06:37 AM
jcddyy's Avatar
A week later and 3gallons of fluid later I finally have decent pressure. The petal still feels a bit spongy but its gonna have to do. Thanks for all the advice. Now that it has been sitting for the majority of two weeks the "Gen" light is on. Who would have thought .. Here we go. I believe this to be a result of it sitting fot a while. Im hope it just needs a battery charge
Old Dec 10, 2011 | 07:20 AM
Well glad you finally got it bled. This is a job I really hate and you know why!
Charge the battery overnight on less than 2A.
The GEN light on is not from sitting - something else is wrong.
With engine running, measure voltage across your battery - should be 13V to 15V. Lower means either ALT or regulator are not working.
Check connections to both, first.
Old Dec 10, 2011 | 07:25 AM
jcddyy's Avatar
Thanks alot. Yup I have drums all the way around and gonna start saving some funds for a conversion next time.
As far as the gen light I charged battery and stzrted right up.. Gen light stayed on . It seems to be dying at idle when brakes applied. Im running a external volt regulator and not sure how to troubleshoot if the regulator or alt is bad. Any advice.. My guess is alt.
Old Dec 10, 2011 | 07:54 AM
What is your voltage reading at idle?
Old Dec 10, 2011 | 09:28 AM
jcddyy's Avatar
Not sure.. Im working now and no meter handy. I pulled in to work at 7a and as soon as I pulled in she died.. I could tell at every stop she wanted to die si I put it in neutral and kept it alive at stops.. Ill check once I get a boost and home. Should be 13 area?
Old Dec 10, 2011 | 09:54 AM
Yes, 13-15V at idle.
Check for disconnected or cracked vac hoses, esp. the one for the brake booster.
If you are driving withthe GEN light on, you may be running off just the battery. If so, it might be getting weak enough to not run the ignition system correctly. I would not drive anywhere until you get it fixed.
Old Dec 10, 2011 | 10:09 AM
jcddyy's Avatar
Im sure its close to it. I have to get home atleast. Whats worse case? Lose power on the highway? Thats bad news..
So how do I narrow down alt or regulator problem? Alt is suppose to keep charge correct? I can take it to auto parts house and test but what if regulator is fried will it burn up alt ?
Vac hoses are brand new from booster.
Old Dec 10, 2011 | 11:39 AM
A parts store can check the alt. If bad, you might open it up to see if just the brushes are worn down. If so, you can replace them for just a few dollars.
If you still have the old original style mechanical regulator, you might just get an electronic replacement - should be under 20 bucks. Check Napa. If that is not the problem, you can always keep it as a spare.
Check your wiring first - look for burned or poor connections at the terminals..
Old Dec 10, 2011 | 12:42 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I can send you another alternator if you want to try it. My cars all use 80's alternators, and I have no use for the older style.
Better to spend 10 bucks on shipping, than 50 bucks for a new one.
You could rebuild your original one while the other is in place, or use mine for the core exchange as well.
That's the only reason I keep it around.
Just a thought.
runnin350
Feb 2, 2014 06:37 AM
veltboy618
Brakes/Hydraulic Systems
Jul 14, 2011 07:10 PM
aliensatemybuick
May 25, 2010 10:02 AM
<marksz71>
Oct 20, 2006 07:14 PM
