Nasty brake line clips - 66 only?
Old Jan 10, 2015 | 05:33 PM
bluecab's Avatar
Mostly Gristle
Can't seem to find these listed on any of the popular sites.
They seem to be a single-use push in type as I have destroyed every one I have taken out.
I don't need to use this particular type, are there other types that will fit in the hole these used?
Old Jan 11, 2015 | 07:40 AM
Run to Rund's Avatar
I haven't seen that type on my 66s. I have some that are like flattened wire looped to make a retainer, and a part that goes into the hole. Others are like a 3/8" wide plate with a nub that goes into the hole, and bent over ends to retain the line. I have seen them reproduced; check the "usual suspects" and you should find them.
Old Jan 11, 2015 | 08:13 AM
bluecab's Avatar
Mostly Gristle
Maybe Toronado only?
Can't imagine why they would re design a line clip for a single model or year.
I'll have to check the hole size, I'd rather have clips that are re-usable.
Old Jan 11, 2015 | 02:46 PM
Inline Tube has a selection of clips similar to the ones I have seen.
gearheads78
Dec 27, 2013 06:47 PM
ToBiN!
Jan 26, 2011 05:57 PM
oldzy
Brakes/Hydraulic Systems
Nov 27, 2010 08:54 PM
Eddie Hansen
May 4, 2010 09:45 AM
oldzy
Apr 24, 2010 09:13 PM
