Nasty brake line clips - 66 only?
Can't seem to find these listed on any of the popular sites.
They seem to be a single-use push in type as I have destroyed every one I have taken out.
I don't need to use this particular type, are there other types that will fit in the hole these used?
I haven't seen that type on my 66s. I have some that are like flattened wire looped to make a retainer, and a part that goes into the hole. Others are like a 3/8" wide plate with a nub that goes into the hole, and bent over ends to retain the line. I have seen them reproduced; check the "usual suspects" and you should find them.
gearheads78
Dec 27, 2013 06:47 PM
oldzy
Apr 24, 2010 09:13 PM
